wise(at)txc.net.au Guest
Posted: Mon Feb 20, 2012 1:16 pm Post subject: Yak elevator |
G’Day All,
Can someone please advise of the problem with the Yak elevator and what the fix is.
I would greatly appreciate some photo’s of the problem and the fix if anyone has any.
Thanks and cheers,
Chris Wise.
(Downunder)
cjpilot710(at)aol.com Guest
Posted: Mon Feb 20, 2012 1:28 pm Post subject: Yak elevator |
Chris,
I assure you are referring to some crashes. There are very close clearances of control horns to air frame in the tail of the Yaks. Any kind of foreign object that happen to get into that area, will almost certainly jam it. Therefore it behooves one to check regularly for ANYTHING that might migrate back there. This would include anything that might fall out of one's pockets, particularly during acro. Although this is true of ANY airplane, the Yak is very susceptible. Are "fix's".
Jim "Pappy" Goolsby
In a message dated 2/20/2012 4:16:53 P.M. Eastern Standard Time, wise(at)txc.net.au writes:
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
Posted: Mon Feb 20, 2012 2:06 pm Post subject: Yak elevator |
G’Day Pappy,
Thanks for that.
I am fully aware of foreign objects and I believe that that was the reason for the crash in New Zealand.
Was it a screwdriver that jammed the elevator?
What I am trying to determine, is as I understand, a problem in the tail sector, is it the elevator bellcrank?
I was told on Sunday that the Yaks tailplanes are now subject to a 25 hour inspection schedule due to some failure.
So what is the problem?
What is the fix?
Does anyone have any photographs relating to this?
Thanks and cheers,
Chris.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Tuesday, 21 February 2012 7:58 AM
To: yak-list(at)matronics.com
Subject: Re: Yak elevator
Chris,
Jim "Pappy" Goolsby
In a message dated 2/20/2012 4:16:53 P.M. Eastern Standard Time, wise(at)txc.net.au (wise(at)txc.net.au) writes:
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
| 01234567890123
wlannon(at)shaw.ca Guest
Posted: Mon Feb 20, 2012 2:07 pm Post subject: Yak elevator |
I addition to the “foreign object” item there is a problem with fatigue cracking of the elevator bellcrank (Yak 52) and loss of elevator control. I do not know all the details but believe there is an airworthiness directive on the subject. Suggest you contact Richard Goode in the UK.
Walt
From: cjpilot710(at)aol.com (cjpilot710(at)aol.com)
Sent: Monday, February 20, 2012 1:27 PM
Chris,
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
Vic
Joined: 12 Aug 2008 Posts: 117 Location: Southern Bavaria
Posted: Mon Feb 20, 2012 3:13 pm Post subject: Re: Yak elevator |
Hi Chris,
this problem is specific for the 52 and and you are running an 18 T ? If I remember correctly Andrey Gluchov has told me that the replacement items are copied in steel to avoid cracks in the elevator aluminium bell cranks. There must have been a series which was not manufactured according to original design.
Cheers
Vic
Posted: Mon Feb 20, 2012 3:34 pm Post subject: Yak elevator |
G'day Vic,
Yes, I am running a 18T.
I have 2 friends with 52's and they raised the subject with me.
Plus my LAME has a number of 52's as well as 18's that he looks after and is
also interested in any information on the subject.
I have been nominated as the gopher to source the info. Bugger is'nt it.
Thanks and cheers,
Chris.
Posted: Mon Feb 20, 2012 5:53 pm Post subject: Yak elevator |
From what I understand Chris, there WAS a Yak 52 where the elevator bellcrank cracked at the point where the elevator counterweight is mounted. I personally have not seen a cracked elevator bellcrank. But that certainly doesn't mean there aren't any out there. The fix is replacing the old with a new elevator bellcrank.
The attached information should answer all your questions.
Dennis
| Quote: | A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com |
On 2/20/2012 4:05 PM, Chris Wise wrote: | Quote: | <![endif]--> <![endif]-->
G’Day Pappy,
Â
Thanks for that.
Â
What is the fix?
Â
Thanks and cheers,
Chris.
Â
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of cjpilot710(at)aol.com (cjpilot710(at)aol.com)
Â
Chris,
I assure you are referring to some crashes. There are very close clearances of control horns to air frame in the tail of the Yaks. Any kind of foreign object that happen to get into that area, will almost certainly jam it. Therefore it behooves one to check regularly for ANYTHING that might migrate back there. This would include anything that might fall out of one's pockets, particularly during acro. Although this is true of ANY airplane, the Yak is very susceptible. Are "fix's".Â
Â
Jim "Pappy" Goolsby
Â
G’Day All,
Â
Â
Thanks and cheers,
Chris Wise.
(Downunder)
   | 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
5 |
DECISION_â„–_Đ‘-46_52-11.docx |
22.98 KB |
504 Time(s) |
sector_replacement.pdf |
152.38 KB |
21814 Time(s) |
Posted: Mon Feb 20, 2012 6:58 pm Post subject: Yak elevator |
Thanks Dennis.
It is becoming very clear.
Chris.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Tuesday, 21 February 2012 12:22 PM
Dennis
| Quote: | | A. Dennis Savarese334-285-6263334-546-8182 (cell)Skype: Yakguy1www.yak-52.com |
G’Day Pappy,
Thanks for that.
What is the fix?
Thanks and cheers,
Chris.
Chris,
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
0334-285-6263 | 123456789
Posted: Mon Feb 20, 2012 7:06 pm Post subject: Yak elevator |
Hi Dennis;
A cracked one was found here a few months back just after the problem was first posted on the list. It was found during an inspection generated by that information. The list works!
Walt
From: A. Dennis Savarese (dsavarese0812(at)bellsouth.net)
Sent: Monday, February 20, 2012 5:51 PM
Dennis
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com |
G’Day Pappy,
Thanks for that.
What is the fix?
Thanks and cheers,
Chris.
Chris,
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
| 012345678901234
5 |
ssssskippy
Posted: Tue Feb 21, 2012 1:58 am Post subject: Yak elevator |
Hi
Here is the Yakovlev decision: http://www.termikas.com/news/DECISION%20%E2%84%96%20%D0%91-46_52-11.doc
And here is the replacement procédure: http://www.termikas.com/news/sector%20replacement.pdf
Have nice flights
Olivier
2012/2/21 Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
[quote] Hi Dennis;
Walt
Dennis
[url=tel:334-285-6263]334-285-6263[/url]
[url=tel:334-546-8182]334-546-8182[/url] (cell)
Skype: Yakguy1
www.yak-52.com |
G’Day Pappy,
Thanks for that.
What is the fix?
Thanks and cheers,
Chris.
Chris,
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
| 0 1234 567 89012 34
5 |
6
Posted: Tue Feb 21, 2012 6:17 am Post subject: Yak elevator |
Hi Walt,
Yes, it most certainly does.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 2/20/2012 9:05 PM, Walter Lannon wrote:
| Quote: | Hi Dennis;
Walt
*From:* A. Dennis Savarese <mailto:dsavarese0812(at)bellsouth.net>
*Sent:* Monday, February 20, 2012 5:51 PM
*To:* yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
*Subject:* Re: Yak elevator
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
> G’Day Pappy,
> Thanks for that.
> What is the fix?
> Thanks and cheers,
> Chris.
> *From:*owner-yak-list-server(at)matronics.com
> [mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of
> *cjpilot710(at)aol.com
> *Sent:* Tuesday, 21 February 2012 7:58 AM
> Chris,
> Jim "Pappy" Goolsby
> wise(at)txc.net.au <mailto:wise(at)txc.net.au> writes:
> G’Day All,
> Thanks and cheers,
> Chris Wise.
> (Downunder)
> *="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List*
> *s.matronics.com/">http://forums.matronics.com*
> *p://www.matronics.com/contribution">http://www.matronics.com/contribution*
> *http://www.matronics.com/Navigator?Yak-List*
> *http://forums.matronics.com*
> *http://www.matronics.com/contribution*
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Tue Feb 21, 2012 1:54 pm Post subject: Yak elevator |
Have a look on the Termikas website and read the elevator discussion
you will perhaps find your answer.
Didier
Le 21 février 2012 02:51, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> a écrit :
| Quote: | From what I understand Chris, there WAS a Yak 52 where the elevator bellcrank cracked at the point where the elevator counterweight is mounted. I personally have not seen a cracked elevator bellcrank. But that certainly doesn't mean there aren't any out there. The fix is replacing the old with a new elevator bellcrank.
Dennis
Skype: Yakguy1
www.yak-52.com |
G’Day Pappy,
Thanks for that.
What is the fix?
Thanks and cheers,
Chris.
Chris,
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris Wise.
(Downunder)
5 |
____________________________
Didier BLOUZARD
Directeur Commercial DATEXIS Portable : +33 6 51 84 48 02
Email: didier.blouzard(at)gmail.com (didier.blouzard(at)anolistech.fr)
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
Etienne Verhellen
Posted: Wed Feb 22, 2012 2:38 am Post subject: Re: Yak elevator |
This problem has been known for a while :
Crack in elevator control system pulley - UK CAA MPD : 2000-004 (27 July 2000). See attachment.
I am surprised Yak-52 pilots are just discovering it now (after the fatal accident in Russia).
It is a required inspection - annually for Yak-52 maintained under the supervision of the UK CAA.
There are of course other important Mandatory Permit Directives (MPD) issued by the UK Civil Aviation Authority for the Yak-52 :
http://www.yakuk.com/MPD.htm
Airframe life limit (confirmed by the Yakovlev Design Bureau) :
http://www.yakuk.com/MPD1998-017R5.pdf
http://www.yakuk.com/MPD2004-006.pdf
Etc ... etc ...
Airframe Overhaul - MANDATORY (AS Yakovlev Design Bureau) - Yak_52_Life_Time_Bulletin.pdf |
114.74 KB |
647 Time(s) |
Crack in elevator control system pulley - UK CAA MPD Nr 2000-004 -27 July 2000..doc |
229.5 KB |
407 Time(s) |
nelsprague(at)hotmail.com Guest
Posted: Fri Feb 24, 2012 9:11 am Post subject: Yak elevator |
I'll send you a picture of an elevator that failedand was hanging when flown home andluckily made it. Brian. Flew it just before failure. .nels
Didier Blouzard <didier.blouzard(at)gmail.com> wrote:
| Quote: | Have a look on the Termikas website and read the elevator discussion
Didier
> Dennis
> G’Day Pappy,****
> Thanks for that.****
> for the crash in New Zealand.****
> Was it a screwdriver that jammed the elevator?****
> sector, is it the elevator bellcrank? ****
> inspection schedule due to some failure.****
> So what is the problem?****
> What is the fix?****
> Does anyone have any photographs relating to this?****
> Thanks and cheers,****
> Chris.****
> *From:* owner-yak-list-server(at)matronics.com [
> mailto:owner-yak-list-server(at)matronics.com<owner-yak-list-server(at)matronics.com>]
> *On Behalf Of *cjpilot710(at)aol.com
> *Subject:* Re: Yak elevator****
> Chris,****
> airplane, the Yak is very susceptible. Are "fix's". ****
> Jim "Pappy" Goolsby****
> wise(at)txc.net.au writes:****
> G’Day All,****
> the fix is.****
> anyone has any.****
> Chris Wise.****
> (Downunder)****
Didier BLOUZARD
Email: didier.blouzard(at)gmail.com <didier.blouzard(at)anolistech.fr>
rijaeger(at)wausau.k12.wi Guest
Posted: Fri Feb 24, 2012 11:04 am Post subject: Yak elevator |
Are you able to post the elevator failure photo on the list...or a link to it? Thanks!!
| Quote: | >> Nelson Sprague <nelsprague(at)hotmail.com> 2/22/2012 12:35 PM >>>
--> Yak-List message posted by: Nelson Sprague <nelsprague(at)hotmail.com>
Didier
> Dennis
> G’Day Pappy,****
> Chris.****
> Chris,****
> G’Day All,****
> the fix is.****
> anyone has any.****
> Chris Wise.****
> (Downunder)****
> *="http://www.matronics.com/Navigator?Yak-List">[url=http://www.matronics.com/Navigator?Yak-List*]http://www.matronics.com/Navigator?Yak-List*[/url]
> *s.matronics.com/">[url=http://forums.matronics.com*]http://forums.matronics.com*[/url]
> *p://www.matronics.com/contribution">[url=http://www.matronics.com/contribution*]http://www.matronics.com/contribution*[/url]
Didier BLOUZARD
Email: didier.blouzard --> http:sp; --> http://forums.matronics. - List p; &= --> ht
Posted: Fri Feb 24, 2012 11:26 am Post subject: Yak elevator |
I'll try and get it on the list, Nels
Date: Fri, 24 Feb 2012 13:02:55 -0600
Didier
> Dennis
> G’Day Pappy,****
> Chris.****
> Chris,****
> G’Day All,****
> the fix is.****
> anyone has any.****
> Chris Wise.****
> (Downunder)****
Didier BLOUZARD
="2" face="courier new,courier">http://www.matronics.com/Navigator?Yak-List
