carlmeek(at)gmail.com Guest
Posted: Sun Feb 19, 2012 11:19 pm Post subject: JabiruEngine-List: Hydraulic or solid.... |
Having owned both, and discussing this with 3 other owners at our field, I am happier with my current solid lifter engine. My previous engine always ran very hot oil temps (from new to 150 hours) despite many attempts to rectify. Oil was always very dark, even 1 flight after oil change. All solid lifter engines on the field ran cooler. To do with hydraulic lifters? Not sure.... But that's what we all blame.
On 19 Feb 2012, at 22:15, "James, Clive R" <clive.james(at)uk.bp.com (clive.james(at)uk.bp.com)> wrote:
[quote] Hydraulic or solid....
2 - Positive Valve Opening. Even at lower revs a hydraulically operated valve suffers from a “soft and soggy” opening operation. By replacing this with a positive mechanical lift, a more precise motion is achieved. This leads to a faster change in manifold vacuum, greater gas speed and ……...more power!
3 - Predictable Operation. Hydraulic lifters are subjected to large and frequent variations in oil pressure and temperature. Solid lifters are a known quantity that simplify valve operation and remove such variables.
4 - Weight and friction reduction. A solid lifter is 10% lighter than it's hydraulic counterpart, and given the overall weight of CVH valve train, this is an important bonus. Any loss of weight in this area will help with engine efficiency and life expectancy. Also, a hydraulic lifter exerts a constant pressure to the total circumference of each lobe base circle resulting in a certain amount of drag. A solid lifter does not contact the camshaft base circle, so internal friction is reduced.
Remind me why they changed them? | Quote: |
st">http://www.matronics.com/Navigator?JabiruEngine-List
cs.com
matronics.com/contribution
dons701
Posted: Mon Feb 20, 2012 1:07 pm Post subject: Re: JabiruEngine-List: Hydraulic or solid.... |
I am looking to convert my early hydraulic 2200A #2456 to solid lifter from GM, (.842" dia.) I need adjustable rockers. Anyone have any for sale before I buy brand new units??...DonB
_________________ Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop |
