Kellym
Posted: Wed Feb 08, 2012 8:41 pm Post subject: Pitot tube mast |
I will be installing the Dynon heated pitot/AOA. They recommend either
the Gretz or SafeAir. While the Gretz is more than double the price, I'm
sitting on the fence. Anyone have strong reasons for one over the other?
Kelly
KCHD |
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Thu Feb 09, 2012 4:53 pm Post subject: Re: Pitot tube mast |
I installed the safeair. The quality looks fine and the install was not difficult.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Kelly McMullen
Posted: Thu Feb 09, 2012 6:19 pm Post subject: Pitot tube mast |
Thanks Bill. I was beginning to wonder if my question made it to the
list. I know some used the Gretz....arguments for it?
On Thu, Feb 9, 2012 at 5:53 PM, bill.peyton <peyton.b(at)sbcglobal.net> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Feb 09, 2012 6:31 pm Post subject: Pitot tube mast |
Hey Kelly,
I have the Gretz. The first one I hooked up melted when I powered it up.
Since SteinAir is so awesome they sent me another one right away. Must have
had a bad batch of pitots way back then. The second one worked/works great.
I would go for the simplest solution. The Gretz has a timer and three
lights for the panel, (fail),(heat),(idle). I think a pitot that you turn
on if there is visible moisture and 10 C or less and forget about it is
good. The only thing I like about the Gretz is there is a light that is on
when it is on. As long as you have a way to remind you it's on. Maybe one
light would be sufficient without a timer. I don't know anything about the
other pitots so I can't say they would be simpler.
Sean
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
mregoan(at)hispeed.ch Guest
Posted: Fri Feb 10, 2012 4:42 am Post subject: Pitot tube mast |
Hi Kelly,
I just finished installing the Gretz mount for the Dynon pitot.
The Gretz kit appears to be slightly more complicated, having a reinforcing backplate riveted to the skin and spar, plus a spacer plate and most of the nutplates and bolts required (except those to join the pitot and mast). The arrangement is obviously heavier (steel mast, more parts) but perhaps more robust (no cracking history). The mast is removable for storage and painting if wanted (eg. with the chrome mast) and is not in place when you rivet the bottom skins on. The mast is bolted afterwards to the reinforcement plate inside the wing.
In consultation with my tech advisor I also added an additional length of J-stiffener along the back edge of the reinforcing plate to reduce skin flexing under load. Altogether it became a little complex (perhaps over engineered) but it shouldn't fall off….
Gordon
41015 Switzerland
64.21 KB |
8077 Time(s) |
napolin(at)me.com Guest
Posted: Fri Feb 10, 2012 10:37 am Post subject: Pitot tube mast |
I installed the gretz. Its pretty straightforward and appears sturdy. Havent flown it yet. Dont know how it compares to others.
Niko
On Feb 9, 2012, at 9:17 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
> Bill Peyton
> http://forums.matronics.com/viewtopic.php?p=365997#365997
Tim Olson
Posted: Fri Feb 10, 2012 11:11 am Post subject: Pitot tube mast |
While the only one I know is the Gretz, I've been happy with it.
I bought it only for it's thermostatic control. I leave it
on for long periods of time and I see by the lights that it
only cycles as-needed. So from an energy (battery) conservation
perspective, I like it. That said, I'd probably not be too
unhappy with any good heated pitot. The gretz mount I liked
either way.
Tim
On 2/10/2012 12:36 PM, Nikolaos Napoli wrote:
Niko
> On Thu, Feb 9, 2012 at 5:53 PM, bill.peyton<peyton.b(at)sbcglobal.net> wrote:
>> Bill Peyton
rv10rob(at)gmail.com Guest
Posted: Fri Feb 10, 2012 12:52 pm Post subject: Pitot tube mast |
I used the Dynon pitot in the Gretz mount. No complaints so far. As Tim notes, the thermostatic control really seems to save power.
On Fri, Feb 10, 2012 at 11:09 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
either way.
Tim
| Quote: | --> RV10-List message posted by: Nikolaos Napoli<napolin(at)me.com (napolin(at)me.com)>
Niko
On Feb 9, 2012, at 9:17 PM, Kelly McMullen<apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: Kelly McMullen<apilot2(at)gmail.com (apilot2(at)gmail.com)>
On Thu, Feb 9, 2012 at 5:53 PM, bill.peyton<peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
| Quote: | --> RV10-List message posted by: "bill.peyton"<peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
Bill Peyton
le, List Admin.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
johngoodman
Posted: Sat Feb 11, 2012 6:05 am Post subject: Re: Pitot tube mast |
I have the Dynon heated AoA with the Gretz mount. Works fine. I remember it was a complicated install.
John
_________________ #40572 Phase One complete in 2011 |
Bob Turner
Posted: Sat Feb 11, 2012 1:25 pm Post subject: Re: Pitot tube mast |
I also have the Gretz mount and the Dynon Pitot. I thought the installation was straightforward. I did it prior to riveting the skin.
The Dynon is, like the Gretz, thermostatically controlled. It will drive a light to show that it's turned on and working. I haven't yet hooked it up to anything other than my GRT EIS.
Software guru's:
Does anyone know if it's possible to code the GRT EIS so that with the OAT < 5 C AND a given analog input (hooked to the pitot sensor) high, it will send a warning? e.g., I'd like to get a pitot heat reminder if I forget to turn it on when the OAT < 5C.
_________________ Bob Turner
RV-10 QB |
rene(at)felker.com Guest
Posted: Sat Feb 11, 2012 4:29 pm Post subject: Pitot tube mast |
How about this for a 2 minute answer.....
Use the coolant temp line on your EIS and set the lower end to alarm at -5C.
Put that line through a normally closed relay that is activated by the pilot
heat (on line)....
Now I can already see a couple of problems with that, but they could be
worked out....like what is the reading with no input...would you have to
provide a false signal for when the heat is on, etc.
Another idea that would work.....a couple of years ago at an AOPA event I
saw a guy selling an ice detector. You could use one of those to warn you
when you have ice. You would have to figure out where to mount it so that
it ices up first so that if you have not turned on the pitot heat you are
not too late. You could use one of the analog lines in the GRT system.
I will put more than two minutes on this later......I am not an electronics
guy....I may have been trained by the Air Force back in the 70's but since
then electricity has changed.....or maybe I have just gotten older.
Bob Turner
Posted: Sat Feb 11, 2012 5:16 pm Post subject: Re: Pitot tube mast |
Rene,
Thanks for your thoughts. Problem is, there is only one analog output for all alarms. I don't want "pitot heat needed" illuminating when it's time to change fuel tanks, for example.
Of course the serial output line has all the info. But that sounds a lot harder.
Bob
RV-10 QB |
Posted: Sat Feb 11, 2012 5:50 pm Post subject: Pitot tube mast |
I was thinking GRT EFIS when I wrote that.
http://www.newavionics.com/9732_oem.html#icing
You could run a separate warning light.....but maybe overkill.
dmaib(at)mac.com Guest
Posted: Sun Feb 12, 2012 4:19 pm Post subject: Pitot tube mast |
I will echo Tim's comments. I have no experience with the others, but
have been very happy with the Gretz. Installation was straight forward.
David Maib
40559
Flying 460 hours
On Feb 10, 2012, at 2:09 PM, Tim Olson wrote:
either way.
Tim
> Niko
>>> "bill.peyton"<peyton.b(at)sbcglobal.net>
>>> was not difficult.
>>> Bill Peyton
