psm(at)att.net Guest
Posted: Wed Feb 08, 2012 5:59 pm Post subject: Zenith601-List: |
Steve,
I mounted the senders on my XL on top of the fuel tanks. They work
fine. I would be concerned about leaks mounting on the side of the tank.
I have heard some owners worry about tank leaks from senders that are a
problem even on top of the tank. There is no easy way to isolate and
repair these since the skin is riveted over the tank. I am taking the
chance, but I've heard some people installed inspection ports over the
sender for possible repairs.
Paul
XL in flight test
On 2/8/2012 4:15 PM, Steve Look wrote:
Howdy,
Just received my fuel senders today. The plan shows them mounted in
the side of the tank and then bending the sender arm into a "Z" shape.
Looking at the "B" upgrade stuff, I see the factory plane has the
sender mounted on top. I've never seen a plan for doing that.
So.... are there opinions on which is better to do and is
documentation available for the top mount? Seems like that might be
less prone to leak.
Steve
Steve Look
Monticello, IL
601XL
"Dogs have owners, Cats have staff"
merlin
Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
Posted: Thu Feb 09, 2012 4:41 am Post subject: Zenith601-List: |
I mounted mine on the side as the plans show. I used a 2 part sealer (B1/2) that is used to seal the wet wings on the aircraft I fly for the Army. I filled both tanks up with fuel and let them sit in the sun for several hours. No leaks and will probably never leak. I don't trust fuel guages in small airplanes anyway. The best fuel guage is your head. Know what you start with, know your fuel burn ( fuel flow meters are very accurate) and dont fly too long.
Oh, the sealant I used is make a MESS but it works great. I think Vans carries it and also Aircraft Spruce.
Have Fun,
Jeff Webb
Fair Play, SC
Sent: Wed, February 8, 2012 7:15:55 PM
Subject: Zenith601-List:
--> Zenith601-List message posted by: Steve Look <slook(at)mchsi.com (slook(at)mchsi.com)>
Howdy,
Just received my fuel senders today. The plan shows them mounted in the side of the tank and then bending the sender arm into a "Z" shape.
Looking at the "B" upgrade stuff, I see the factory plane has the sender mounted on top. I've never seen a plan for doing that.
So.... are there opinions on which is better to do and is documentation available for the top mount? Seems like that might be less prone to leak.
Steve
Steve Look
Monticello, IL
601XLcs.com/Navigator?Zenith601-List" target=_blank>http://www.matronics.com/N========================
Brad(at)ocbis.com Guest
Posted: Thu Feb 09, 2012 1:19 pm Post subject: Zenith601-List: |
Steve -
I'm in the process of mounting my senders on the top. My tanks are 2005
vintage and the tank top is real close to the LE skin, leaving clearance
issues to the skin. What I ended up doing was making a spacer plate that
mounted the sender inside the tank by a 1/4 inch, giving me enough
clearance. My thinking is that having the sender at the top is going to have
to minimize leaks just because it is not going to be immersed in the fuel
all the time like the side mount sender is.
As for future reparability, I counted the main spar rivets so I know exactly
where the center of the sender is and made measurements using that rivet for
reference, and logged it. So now I know exactly where to cut in the future
to replace it (if I have to). I'll fab a cover at that time if needed. To
me, a leak seems a lot more likely than the sender going out. Also if a leak
did develop and I could not repair it quickly, I could lower the fuel level
in the tank to stop the leak with the sender at the top, where it would just
keep leaking with the side mount.
Good luck with it. - Brad
