maca2790
Posted: Tue Feb 07, 2012 2:47 pm Post subject: Drilling the Spar Web? |
Hi, I'm thinking about drilling the Spar web under the co-pilots seat so that I can mount my Safety Trim control box. Has anyone done similar or
have any thoughts on it?
cheers
John MacCallum
Builder 41016
VH-DUU
rv10flyer(at)verizon.net Guest
Posted: Tue Feb 07, 2012 3:49 pm Post subject: Drilling the Spar Web? |
don't drill the spar.
put it on the landing gear mount or somewhere else.
Posted: Tue Feb 07, 2012 5:05 pm Post subject: Drilling the Spar Web? |
Since most people have the control stick cable going to behind the panel to
connect the other stick switches, this tends to be a better place to mount
the Safety Trim box. Mine is mounted on the next forward bulkhead, top left
corner.
Carl
Tim Olson
Posted: Tue Feb 07, 2012 5:39 pm Post subject: Drilling the Spar Web? |
I wouldn't drill it. But, that plastic high-strength velcro 2" wide
would work perfectly.
Tim Olson - RV-10 N104CD
On 2/7/2012 4:47 PM, maca2790 wrote:
cheers
John MacCallum
Builder 41016
VH-DUU
http://forums.matronics.com/viewtopic.php?p=365827#365827
robin(at)PaintTheWeb.com Guest
Posted: Tue Feb 07, 2012 6:13 pm Post subject: Drilling the Spar Web? |
Dual Lock is great stuff. I put in in some products I manufacture. It comes in a couple of different interlocking head density as well as in Black or Clear. It can be purchased in any HD / LOWES aviation department or on eBay
Tim Olson
jump2(at)sbcglobal.net Guest
Posted: Wed Feb 08, 2012 5:13 am Post subject: Drilling the Spar Web? |
Here's where a couple of us put it. Be sure to clean up holes.
Patrick Thyssen
N15PT
--- On Tue, 2/7/12, maca2790 <vk2gcn(at)cirruscomms.com.au> wrote:
Subject: Drilling the Spar Web?
Date: Tuesday, February 7, 2012, 4:47 PM
--> RV10-List message posted by: "maca2790" <[url=/mc/compose?to=vk2gcn(at)cirruscomms.com.au]vk2gcn(at)cirruscomms.com.au[/url]>
cheers
John MacCallum
Builder 41016
VH-DUU
--> http://www.matronics.com/contribution============
2.39 MB |
8372 Time(s) |
2.16 MB |
8372 Time(s) |
maca2790
jchang10
Posted: Thu Feb 09, 2012 2:10 pm Post subject: Re: Drilling the Spar Web? |
Instead of drilling new holes, i first try using any existing holes. Thus, I used the existing spar attach bolts to attach a small shelf for holding all my control stick wiring and connections, which worked out well.
Unfortunately, i can't find photos of my install. FWIW.
Jae
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Tim Olson
Posted: Thu Feb 09, 2012 2:51 pm Post subject: Drilling the Spar Web? |
Hey John,
While I suggested the velcro, and think it could be perfect
for the use, I have one more thing for a thinking point.
If you do use velcro, pay close attention to the overall
installation. Remember that your controls are under the seat
as well. So ANYTHING you put under the seat, be wary that
it's secured in such a way that if it breaks free it can't
jam the controls. I'd be fine using velcro, but, you
probably should put a cable clamp on the harness, perhaps
secured with an adel clamp to the gear leg mount or something.
That way if it does break free, it can't get near the stick.
Just wanted to keep that thinking point out there because
anytime you do anything around the control surfaces, be
extra careful. That goes for people putting things down the
center tunnel as well.
On 2/9/2012 3:40 PM, maca2790 wrote:
"maca2790"<vk2gcn(at)cirruscomms.com.au>
Thank you Patrick for the photos. That's is precisely the sort of
thing I was thinking about doing. I asked Vans about drilling the
Web and they seemed to think it would be ok as long as the holes were
small and not great in number. I think 4 x #19 holes would qualify in
that respect.
As for the 3M Velcro I think that Idea has merit as well. I have
actually got some here that I had used to mount a Remote Control Head
for a Ham radio in my SUV. It worked well for about 8 months and then
the Sun eventually melted the glue and it fell off. (it gets hot in
Aussie) I still can't get the glue off the Dashboard
thank you all
John MacCallum Builder 41016 VH-DUU
maca2790
Posted: Thu Feb 09, 2012 3:49 pm Post subject: Re: Drilling the Spar Web? |
Good point Tim. I was also thinking of trying to make some sort of bracket that I could hang off the cover plate that is under the seat.
Maybe something coming off the existing bolts on the Undercarriage mounts would be good as well. I will have a think about it.
Another thought I just had is to make some sort of tray arrangement so that the tray captures anything that falls off before it falls onto the control rods.
thanks all again.
John MacCallum
Builder 41016
