first_flights(at)yahoo.co Guest
Posted: Sun Feb 12, 2012 5:27 pm Post subject: Position where the Brake and Fuel Tank Vent Lines intersect |
I am trying to install the Brake and Fuel Tank Vent Lines before installing the wings.
The plans give little direction as to where these lines are the intersect the fuselage. It appears that the Brake Line bulkhead fitting intersects the fuselage inboard of where the wing skin projects onto the fuselage and forward of the fuselage Fuel Tank Bracket. Whereas, the Fuel Tank Vent Line intersects the fuselage below where the wing skin projects onto the fuselage, in front of vertical stiffner and above the 3/4" x 3/4" extrusion.
Am I on the right track? Anyone have any dimensions or pictures that they could share?
Finally, it appears that the two forward bolts that attaches the mount for the tricyle landing gear is just outboard of where the wing skin projects onto the fuselage. Correct?
Thanks.
Brett Herrick
RV-6A, Working on the cockpit area
Columbus, IN
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
