aerobubba(at)earthlink.ne Guest
Posted: Thu Jan 26, 2012 7:56 am Post subject: fuses, breakers, and hydraulic pumps |
Hi Jeff-
With regard to:
| Quote: | How about another example ? The popular approach is to use a pullable
breaker for the hydralic pump for the amphibious landing gear. If I
use a switch and a fuse, what size fuse ? I appreciate that I can
always install a bigger fuse if nuisance pops occur, .....
.....Are there any other reasons why a pullable circuit breaker would be
| Quote: | preferred for this situation ?
There are two seperate potential issues here. First, is there an alternate source of hydraulic pressure? If you have a practical hand pump available, then the nuisance trip issue is just that. If the electric pump is your only practical source of hydraulic power, then things are a little different. I could envision a scenario where the motor for the hydraulic pump has degraded such that the current draw trips the circuit protection, leaving you with a gear up landing, or potentially worse, a partial gear landing. Personally, I would prefer resettable circuit protection in that scenario.
FYI, YMMV, ETC, ETC
Glen Matejcek
Posted: Thu Jan 26, 2012 9:17 am Post subject: fuses, breakers, and hydraulic pumps |
There are two separate potential issues here. First, is there an
Cogent thoughts my friend. In spite of the fact that
a Beech Sierra was a pig with wings, I appreciated the
fact that the standby-gear extension system was a simple
valve on the floor that allowed gear-up pressure to be
relieved allowing the wheels to fall free.
I would offer the notion that if power to the motor
is sufficiently robust (current limiter style
protection) then a nuisance trip is entirely out
of the picture. Any time you open a current limiter,
something is REALLY BAD WRONG and being able to
"give 'er one more try" is an incalculable long
shot.
