Pete Fowler
Posted: Sun Jan 08, 2012 6:17 pm Post subject: J9-G1 prop problem |
Had a problem this weekend at an airshow. The prop control stopped working. What happened was that at high MP, the prop started overspeeding so I pulled the prop lever and power and got an RPM and MP that allowed a safe landing.
We replaced the prop governor and I went and did a test flight and other than only getting about 2150 rpm (we guessed at the adjustment) it worked great.
So I started the airshow and the first time I pulled the power while doing a rejoin, the prop started overspeeding same as the previous day. It was totally unresponsive to the prop control and I orbited for altitude while assessing and once I'd reached a good glide altitude to the runway I tried cycling the prop and it "came back to life" and was able to be adjusted and was responsive (held RPM at different MP).
Once I got to my home airport, I tried adjusting it while overhead and it completely stopped working again (I had to reduce MP to keep the RPM safe). Landed safely and tried cycling it on the ground and it worked but the prop control lever was "sticky".
Note that in all our examination and work on the governor, the linkage was and is free and correct and there was resistance on the governor. I assume it's a problem in the prop hub itself but does anyone have any ideas?
wlannon(at)shaw.ca Guest
Posted: Sun Jan 08, 2012 8:49 pm Post subject: J9-G1 prop problem |
Pete;
Check to see if the prop control copper sleeve is moving with the cable. It
should be clamped solid about 10" or so left of the governor.
Walt
pilotdog57(at)aol.com Guest
Posted: Mon Jan 09, 2012 6:24 am Post subject: J9-G1 prop problem |
I think prop hub. When was it last overhauled?
DZ
On Jan 8, 2012, at 6:17 PM, "Pete Fowler" <pfdesign1(at)cox.net> wrote:
http://forums.matronics.com/viewtopic.php?p=362796#362796
Pete Fowler
Posted: Sun Jan 15, 2012 6:54 pm Post subject: Re: J9-G1 prop problem |
Doug, you called it. It was the prop hub. Though the linkage did have some issues, as soon as we pulled the dome and oil piston, the blades wouldn't turn with all my weight on them (they're supposed to turn by hand easily at that point).
Posted: Sun Jan 15, 2012 8:29 pm Post subject: J9-G1 prop problem |
Even those things need an overhaul now and then....I'll bet it was way overdue by time.
That old grease turned into something else. Vladimir is expert in servicing these things if you do not want a traditional prop shop. Most of the seals are the same as V -530 Russki prop.
DZ
On Jan 15, 2012, at 6:54 PM, "Pete Fowler" <pfdesign1(at)cox.net> wrote:
http://forums.matronics.com/viewtopic.php?p=363936#363936
Pete Fowler
Posted: Mon Jan 23, 2012 8:47 am Post subject: Re: J9-G1 prop problem |
After thoroughly cleaning the hub, the issue was that it still had the Chinese grease. I can't believe someone installed a prop hub without cleaning and changing the grease to Aeroshell 5 but that's what happened. Works better than new now that it's all cleaned, re-greased and I put new seals in while I had it apart.
If you have one of these hubs (Yak or CJ) and aren't 100% sure that it has U.S. grease, and it's not getting cleaned, inspected and redone every year during your conditionals...you should do it NOW.
Two guys literally could not move the prop with the piston removed with that grease in there.
Posted: Mon Jan 23, 2012 11:10 am Post subject: J9-G1 prop problem |
Every Year? Rebuild the prop? Especially after cleaning it completely and re assembling with US grease along with new seals.
Doc
brian(at)lloyd.com Guest
Posted: Mon Jan 23, 2012 11:40 am Post subject: J9-G1 prop problem |
On Mon, Jan 23, 2012 at 11:07 AM, Roger Kemp <viperdoc(at)mindspring.com> wrote:
I thought he was just suggesting cleaning it and replacing the grease
on an annual basis. I agree that might be overkill but I don't think
it would be a bad thing.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
Posted: Mon Jan 23, 2012 12:02 pm Post subject: J9-G1 prop problem |
Greasing the hub means pulling the blades out of the hub, which also
means re-indexing the blades when you put them back in. It also means
replacing all the seals.
Personally, if my prop moves freely and does not leak oil or grease, I
don't pull the blades out every year just to put new grease in.
Different story if they are spewing grease out of the seals and all over
the blades!
I'll probably be shot at sun-rise for admitting that. But that is
just me making a risk versus value assessment. To each his own.
Mark Bitterlich
p.s. On the same note: Both mags have grease inside their gear
reduction assembly. Which probably means that we should ........ ??
Posted: Mon Jan 23, 2012 12:22 pm Post subject: J9-G1 prop problem |
Actually you don't have to pull the blades to clean and grease the
bearings. The only time one needs to pull the blades is to 1) replace
the seals inside the large castellated nuts by removing the
counterweight collars and then sliding the large castellated nuts out
over the opening or 2) to replace the blades or remove them to have them
refinished.
To grease the hub all one has to do is remove the large castellated nut
locking tab in the front of the hub and unscrew the large castellated
nut. This will expose the inner bearing and race, the slider. The
outer bearing will be accessible on the blade assembly that is removed
as an assembly when you unscrew the large castellated nut. Of course
the prop hub dome and piston must be removed first.
If there are weights mounted on the large castellated nuts, be certain
to mark them and their position in relation to the hub before removing them.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/23/2012 1:58 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14
the blades!
Mark Bitterlich
Posted: Mon Jan 23, 2012 12:32 pm Post subject: J9-G1 prop problem |
BTW, removing the entire blade assembly as mentioned does not affect the
blades angles since the counterweight collar is not loosened as it would
be to unscrew a blade.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/23/2012 2:19 PM, A. Dennis Savarese wrote:
<dsavarese0812(at)bellsouth.net>
them refinished.
nut locking tab in the front of the hub and unscrew the large
castellated nut. This will expose the inner bearing and race, the
slider. The outer bearing will be accessible on the blade assembly
that is removed as an assembly when you unscrew the large castellated
nut. Of course the prop hub dome and piston must be removed first.
them.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
64E wrote:
> Point, MALS-14 64E"<mark.bitterlich(at)navy.mil>
> the blades!
> Mark Bitterlich
N13472(at)aol.com Guest
Posted: Mon Jan 23, 2012 1:00 pm Post subject: J9-G1 prop problem |
The Chinese manual say's to pack some grease on the inside of the hub on the
bearing area. As there are no inside
seals centrifugal force will push / pull the grease into the bearing race
area. When I do this to mine I get a small amount
of grease coming out past the seals for the next couple of flights.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 702-595-2680
Posted: Mon Jan 23, 2012 1:29 pm Post subject: J9-G1 prop problem |
Alot of extra work for little return. If memory serves correct since I don't have my maint. manual at hand currently but...200 hours comes to mind for the Yak. I could be wrong. Maybe different for the CJ.
Doc
Posted: Mon Jan 23, 2012 3:06 pm Post subject: J9-G1 prop problem |
On Mon, Jan 23, 2012 at 1:26 PM, Roger Kemp <viperdoc(at)mindspring.com> wrote:
You don't fly your airplane 200 hours per year? I know that when I had
my (flying) CJ I certainly did.
3191 Western Dr.
brian(at)lloyd.com
Pete Fowler
Posted: Mon Jan 23, 2012 4:02 pm Post subject: Re: J9-G1 prop problem |
I'm interested in what material the bushing inside the hub nut was. It looked like plastic or wood or something but that was some funkey purple plastic!
Posted: Mon Jan 23, 2012 5:19 pm Post subject: J9-G1 prop problem |
I stand corrected.
Thank you Dennis.
Mark
p.s. I greased my prop 5 years ago and replaced the prop blade seals at the same time. (They were leaking grease). Since then I have not done anything with the prop except inspect it carefully before and after every flight). I encourage everyone to make their own decisions.
From: owner-yak-list-server(at)matronics.com on behalf of A. Dennis Savarese
Sent: Mon 1/23/2012 3:19 PM
To: yak-list(at)matronics.com
Subject: Re: Re: J9-G1 prop problem
refinished.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
the blades!
Mark Bitterlich
Posted: Mon Jan 23, 2012 5:20 pm Post subject: J9-G1 prop problem |
I unscrewed the blades.
Sent: Mon 1/23/2012 3:29 PM
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
them refinished.
them.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
> the blades!
> Mark Bitterlich
Posted: Mon Jan 23, 2012 5:25 pm Post subject: J9-G1 prop problem |
I don't either Brian. About 100 hours per year for the first couple of years, and now less than that.
Of course I have two airplanes to fly and they both have been flying constantly since I purchased them. No down time.
Mark
From: owner-yak-list-server(at)matronics.com on behalf of Brian Lloyd
Sent: Mon 1/23/2012 6:02 PM
3191 Western Dr.
brian(at)lloyd.com
Posted: Mon Jan 23, 2012 7:42 pm Post subject: J9-G1 prop problem |
Nay.
Doc
