phactor9
Posted: Wed Jan 18, 2012 9:48 am Post subject: Back to topic! Kolb coolness! |
I agree! Therefore, here's some fun Kolb Firefly schtuff:
Engine and muffler mounting plate custom designed and fabricated by Bryan Melborn at Kolb Co. specifically for my new Firefly's CRE mz201 engine:
http://phactor.com/mtgPlates_2.jpg
http://phactor.com/eng_a.jpg
http://phactor.com/eng_a3.jpg
I made the pulley myself:
http://phactor.com/psp4.jpg
Made the coil mount myself:
http://phactor.com/coil_c.jpg
http://phactor.com/coilParts.jpg
http://phactor.com/coilPlacement.jpg
And finally, I updated my mz201 weights and pics page with Bryan's engine/muffler mount weight/pics:
http://phactor.com/Kolb/201/201.htm
Phil H
FF-11-4-0076
--- On Wed, 1/18/12, John Hauck <jhauck(at)elmore.rr.com> wrote:
Subject: RE: Re: changes in EAA?
Date: Wednesday, January 18, 2012, 9:57 AM
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
That quotation from Albert Einstein >>
I have looked up the page you mentioned.
Kolbers:
We are getting way off base here.
Let's get back to the primary purpose of the Kolb List, building and flying
Kolbs.
mkIII<//www.matronics.com/Navigator?Kolb-List" target=_blank>http://www.matronip; -Matt Draronics.com/contribution" =======
| [quote][b]
capedavis(at)yahoo.com Guest
Posted: Wed Jan 18, 2012 11:04 am Post subject: Back to topic! Kolb coolness! |
Phil, Hi Nice work you and Bryan did on your Firefly! Did you see my post on the info i got from Leon at MZ It turned out that the engine weighs 2 lbs more with the fan cooling but Leon says as Im sure he told you that he has no doubt about the free air cooling on the Firefly so the $560 for the fan cooling might be saved .I guess Ill leave up to you to be the test pilot before I order.
That Bryan does some nice work. Is the rest the aircraft coming along well ?I hope to be able to afford a trip to my place and my Firefly in Florida maybe the first of March . Keep up the good work .Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Wednesday, January 18, 2012 12:45 PM
Subject: Back to topic! Kolb coolness!
Engine and muffler mounting plate custom designed and fabricated by Bryan Melborn at Kolb Co. specifically for my new Firefly's CRE mz201 engine:http://phactor.com/mtgPlates_2.jpghttp://phactor.com/eng_a.jpghttp://phactor.com/eng_a3.jpg
I made the pulley myself:http://phactor.com/psp4.jpg
Made the coil mount myself:http://phactor.com/coil_c.jpghttp://phactor.com/coilParts.jpghttp://phactor.com/coilPlacement.jpg
And finally, I updated my mz201 weights and pics page with Bryan's engine/muffler mount weight/pics:http://phactor.com/Kolb/201/201.htm
Phil HFF-11-4-0076--- On Wed, 1/18/12, John Hauck <jhauck(at)elmore.rr.com> wrote:
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>That quotation from Albert Einstein >>I have looked up the page you mentioned.********************************************Kolbers:We are getting way off base here.Let's get back to the primary purpose of the Kolb List, building and flyingKolbs.Thanks,john hmkIII http://www.matronip; -Matt Draronics.com/contribution" =======
=nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List
captainron1(at)cox.net Guest
Posted: Wed Jan 18, 2012 12:00 pm Post subject: Back to topic! Kolb coolness! |
Nice work all around.
Phil H
FF-11-4-0076
I have looked up the pageĀ you mentioned.
Kolbers:
Kolbs.
le, List Admin.
Ron (at) KFHU
phactor9
Posted: Wed Jan 18, 2012 12:04 pm Post subject: Back to topic! Kolb coolness! |
Yes, I saw your post; good information. It confirms what I also have found by talking with CRE, and all the weights on my mz201 page are still accurate; although they do not include the fan shroud, which I didn't opt for.
Yes I will certainly be the mz201-on-a-Kolb-Firefly guinea pig and share the results; still a couple of months off. A couple of months ago I still had to move from DE to TN, sell a home, buy a home, and THEN order a Firefly. Well, got all that done! Building is going great; working on the electrical and instruments now - almost half-way through the plane.
And yes, Bryan and Travis are wizards.
Phil H
FF-11-4-0076
--- On Wed, 1/18/12, chris davis <capedavis(at)yahoo.com> wrote:
Subject: Re: Back to topic! Kolb coolness!
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Wednesday, January 18, 2012, 2:01 PM
Chris Davis
KXP 503 492 hrs
Glider Pilot
Engine and muffler mounting plate custom designed and fabricated by Bryan Melborn at Kolb Co. specifically for my new Firefly's CRE mz201 engine: http://phactor.com/mtgPlates_2.jpg http://phactor.com/eng_a.jpg http://phactor.com/eng_a3.jpg
I made the pulley myself: http://phactor.com/psp4.jpg
Made the coil mount myself: http://phactor.com/coil_c.jpg http://phactor.com/coilParts.jpg http://phactor.com/coilPlacement.jpg
And finally, I updated my mz201 weights and pics page with Bryan's engine/muffler mount weight/pics: http://phactor.com/Kolb/201/201.htm
Phil H FF-11-4-0076 --- On Wed, 1/18/12, John Hauck <jhauck(at)elmore.rr.com> wrote:
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com> That quotation from Albert Einstein >> I have looked up the page you mentioned. ******************************************** Kolbers: We are getting way off base here. Let's get back to the primary purpose of the Kolb List, building and flying Kolbs. Thanks, john h mkIII http://www.matronip; -Matt Draronics.com/contribution" =======
et=_blank>http://forums.matronics.com
| [quote][b]
