bnelson79
Posted: Thu Jan 12, 2012 7:41 pm Post subject: Falcon amp/volt gauge hookup |
Ive just gotten a combo Falcon amp/volt gauge. It has four connections on the back. Two connect to either side of the shunt. The third to ground. But the fourth is supposed to connect to the ignition switch. But I have an ACS rotary switch with multiple connections. The gauges are not reading though and I assume it's because this fourth connection is not right. Does anyone know how this last wire should be attached to the ignition switch?
Bill
kuffel(at)cyberport.net Guest
Posted: Thu Jan 12, 2012 9:08 pm Post subject: Falcon amp/volt gauge hookup |
Bill,
<< Falcon amp/volt gauge. .. four connections .. But the fourth is supposed
to connect to the ignition switch. .. how this last wire should be attached
to the ignition switch? >>
Believe it goes to the BAT terminal which is at about 11 o'clock viewed from
the back on the ACS switch. You will need to crimp the proper sized ring
terminal onto the wire. The BAT terminal is the source of power for the
starter solenoid.
Tom Kuffel
