CJohnston(at)popsound.com Guest
Posted: Wed Jan 11, 2012 5:00 pm Post subject: New Headset Bracket Design |
Did you get a 3 axis CNC mill for Christmas? Sure seems like it!
cj
On Jan 11, 2012, at 1:17 PM, Robin Marks wrote:
| Quote: | We have recently been playing around with a headset bracket that would work with the beautiful Aerosport interior we recently installed. In my 8A we went the simple route with a color matched nylon strap and Velcro to hold the headsets when not in use. For the RV-10 I wanted the headsets low & out of the way for several reasons. Because of how low I wanted the headsets using a strap was not that easy to reach. We built up a hanging bracket that is ultra-light weight (thin material) and hangs over the edge of the interior paneling. Works well so far and keeps the headsets substantially out of view.
Robin
<image001.jpg><image002.jpg><image003.jpg>
Chris Johnston (CJ)
Re-recording Mixer / Sound Supervisor
POP Sound
625 Arizona Ave.
Santa Monica, CA 90401
310.587.1255 (direct)
310.587.1222 (fax)
310.770.9548 (cell)
cjohnston(at)popsound.com (cjohnston(at)popsound.com)
www.popsound.com
robin(at)PaintTheWeb.com Guest
Posted: Wed Jan 11, 2012 5:25 pm Post subject: New Headset Bracket Design |
This was done on a standard lathe. I have a 5 axis CNC lathe plus several Haas CNC mills at my factory but the only thing more expensive than hiring these jobs out is to build ANYTHING in house. My father-in-law was famous for saying "why buy something when we can build it for three times the price" He was right…
Nice to see you on the list Chris! My 8A is down for a new top end. Flew great as it was and very fast too but the warning signs were there so 4 new flow matched, ported & polished cylinders are headed my way.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston
Sent: Wednesday, January 11, 2012 4:53 PM
Subject: Re: New Headset Bracket Design
cj
Robin
Chris Johnston (CJ)
POP Sound
625 Arizona Ave.
310.587.1222 (fax)
310.770.9548 (cell)
www.popsound.com
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] nbsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
flysrv10(at)gmail.com Guest
Posted: Fri Jan 13, 2012 3:12 am Post subject: New Headset Bracket Design |
Well... do tell how we can buy a pair.
Rob Kermanj
Robin
Posted: Fri Jan 13, 2012 8:21 am Post subject: New Headset Bracket Design |
Rob, I was just showing our solution. No commerce here. If you can’t make a set then I would try go with the nylon strap & Velcro. Making those are ultra easy and they work just as well it's just a little harder to reach to put in the headsets in place. I will try to snap a few photos soon of the setup we use on the 8A.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Friday, January 13, 2012 3:09 AM
Rob Kermanj
Robin
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
paul(at)bwbco.com Guest
Posted: Fri Jan 13, 2012 9:00 am Post subject: New Headset Bracket Design |
Robin, Would you please call me re your gust locks?Paul Bowmar (435) 826-4601
On Jan 13, 2012, at 9:19 AM, Robin Marks wrote:
| Quote: | Rob, I was just showing our solution. No commerce here. If you can’t make a set then I would try go with the nylon strap & Velcro. Making those are ultra easy and they work just as well it's just a little harder to reach to put in the headsets in place. I will try to snap a few photos soon of the setup we use on the 8A.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Rob Kermanj
Robin
============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============== bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin.bution">http://www.matronics.com/contribution ============== | Quote: |
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
Posted: Fri Jan 13, 2012 9:10 am Post subject: New Headset Bracket Design |
Got it. Thanks
Do not archive.
Rob Kermanj
Robin
Rob Kermanj
Robin
============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp; - MATRONICS WEB FORUMS - :p>tp://forums.matronics.com ============== bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============== | Quote: |
Posted: Sun Jan 15, 2012 6:25 pm Post subject: New Headset Bracket Design |
Attached is a cell photo of the nylon strap headset solution. I have seen thinner strapping used and it probably works better. This strapping was excess from my seatbelts so I figured why not (the pax don't need no stinking seatbelts).
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Friday, January 13, 2012 8:19 AM
Subject: RE: New Headset Bracket Design
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] ([email][mailto:owner-rv10-list-server(at)matronics.com][/email]) On Behalf Of Rob Kermanj
Rob Kermanj
Robin
/o:p>
:p>
============== ==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] nbsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [/quote]
1.28 MB |
4614 Time(s) |
