rick(at)rvairshows.com Guest
				 Posted: Tue Jan 10, 2012 6:56 am    Post subject: Fuel leaking from throat of M14P Carburettor |
				Dale,
   What is your correct e-mail address? I have an offline question for you.
 Rick VOLKER
 On Jan 10, 2012, at 7:19 AM, "Dale" <hdinamic(at)qwest.net> wrote:
  Try tightening the bolts on the diaphram.  You could also have a corroded orface in diaphram port or a defective diaphram.   Most likely one of these.  Fuel issues with diaphram will cause fuel to leak out the ram air sensor tubes located around the inlet of the carb venturi.
  http://forums.matronics.com/viewtopic.php?p=362914#362914
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
