sean(at)stephensville.com Guest
Posted: Fri Jan 06, 2012 1:28 pm Post subject: Door Half Index Holes |
Anyone else have the top two index holes in the door halves not line
up? On mine the bottom two and the fore and aft index holes line up
fine but the top two do not. I clecoed the fore and aft index holes to
the fuselage on the cabin top along with the bottom two window index
holes. They all line up fine.
I am thinking I can just leave the bottom two clecoed to the fuse and
keep the bottom two window index holes clecoed and clamp them together
tight and re-drill the top two index holes?
Sean #40303
kearney
Posted: Fri Jan 06, 2012 2:14 pm Post subject: Door Half Index Holes |
Hi Sean
I had the same problem. I just created new holes after I aligned the halves.
Cheers
Les
On 2012-01-06, at 2:16 PM, Sean Stephens <sean(at)stephensville.com> wrote:
Anyone else have the top two index holes in the door halves not line up? On mine the bottom two and the fore and aft index holes line up fine but the top two do not. I clecoed the fore and aft index holes to the fuselage on the cabin top along with the bottom two window index holes. They all line up fine.
I am thinking I can just leave the bottom two clecoed to the fuse and keep the bottom two window index holes clecoed and clamp them together tight and re-drill the top two index holes?
Sean #40303
john(at)trollingers.com Guest
Posted: Fri Jan 06, 2012 2:16 pm Post subject: Door Half Index Holes |
I would treat the index holes as approximations, mine lined up, but I
have heard and read of lots of people having issues with those not
lining up. Get the mated the way you want and just re-drill the
holes.
If this is your first venture in to the fiberglass work envolved in
the RV-10 hold on, the ride is going to get worse before it gets
better.
On Fri, Jan 6, 2012 at 4:16 PM, Sean Stephens <sean(at)stephensville.com> wrote:
up fine.
Sean #40303
rv10rob(at)gmail.com Guest
Posted: Fri Jan 06, 2012 3:40 pm Post subject: Door Half Index Holes |
I used the two index holes near the bottom of the door (I believe they're near where the door pins will be). I used two clecos in those holes to hold the door to the fuselage, then drilled new holes. If I'd used the actual index holes at the top, the door would have been very twisted.
-Rob
On Fri, Jan 6, 2012 at 2:09 PM, John Trollinger <john(at)trollingers.com (john(at)trollingers.com)> wrote:
| Quote: | --> RV10-List message posted by: John Trollinger <john(at)trollingers.com (john(at)trollingers.com)>
holes.
better.
On Fri, Jan 6, 2012 at 4:16 PM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
> --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
> up fine.
> Thanks,
> Sean #40303
http://forums.matronics.com
le, List Admin.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
philperry9
Posted: Fri Jan 06, 2012 3:44 pm Post subject: Door Half Index Holes |
They're far from perfect. Just slide the two halves together and get the best possible fit, then drill your own reference holes.
On Fri, Jan 6, 2012 at 4:09 PM, John Trollinger <john(at)trollingers.com (john(at)trollingers.com)> wrote:
[quote]--> RV10-List message posted by: John Trollinger <john(at)trollingers.com (john(at)trollingers.com)>
holes.
better.
> up fine.
> Thanks,
> Sean #40303
le, List Admin.
Posted: Fri Jan 06, 2012 8:05 pm Post subject: Door Half Index Holes |
Thanks guys. Will proceed as planned.
-Sean #40303
DO NOT ARCHIVE
On 1/6/12 5:36 PM, Phillip Perry wrote:
| Quote: | They're far from perfect. Just slide the two halves together and get
<mailto:john(at)trollingers.com>> wrote:
<john(at)trollingers.com <mailto:john(at)trollingers.com>>
holes.
better.
line up? On
fine but the
fuselage on
They all line
> up fine.
fuse and keep
together tight and
> Thanks,
> Sean #40303
le, List Admin.
