Speaking of Vertical Power VP-200 and VP-X...
Site Admin
PostPosted: Sat Dec 31, 2011 4:37 pm    Post subject: Speaking of Vertical Power VP-200 and VP-X... Reply with quote
At 12:48 PM 12/31/2011 Saturday, Ralph Finch wrote:
Matt, what do you think about the VP-X? It's a lot cheaper but doesn't have the flight modes or extra display and thus requires all the switches still (just no circuit breakers).
Ralph Finch
Davis
The Vertical Power VP-X is definitely a step in the right direction for your typical Experimental aircraft electrical system. It also allows you to use standard small signal switches for even the largest of current circuits which saves space, weight, and money. If the VP-200 didn't exist, there is no question that I would use the VP-X for my Experimental nerve center.
That being said, the VP-200 adds *so* much more functionality over the VP-X, I would always recommend it first. The VP-200 truly infuses 21st century technology with our Experimental aircraft. Given the quality and functionality it brings to the table, it is exceptionally well priced. If I were on a tight budget, I would forgo a second GPS, Comm, or EFIS display before I would sacrifice the functionality provided by the VP-200.
The VP-200 rates a 5 out of 5 in my opinion.
( BTW, I don't get a kick back from Vertical Power; I'm just a very happy, satisfied and *repeat* customer. Smile )
Matt "Red Dawg" Dralle
Status: 48+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
rleffler
PostPosted: Sat Dec 31, 2011 5:39 pm    Post subject: Speaking of Vertical Power VP-200 and VP-X... Reply with quote
The only problem is that the VP-200 is end of life and out of stock. It's
replacement, the VP-400 won't be formally announced until SnF. It's either
wait or go VP-X.
I concur that the VP-200 is a great piece of gear. I ended up going with
the VP-X strictly due to budget reasons. Either way you can't go wrong.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
kearney
PostPosted: Sat Dec 31, 2011 6:35 pm    Post subject: Speaking of Vertical Power VP-200 and VP-X... Reply with quote
Hi
FWIW, I went the VP-X route out of choice. I like the integration with the
AFS 4500 EFIS and didn't have the panel space for the VP-100 display. I have
recently powered up the VP-X along with the EFIS and am very impressed with
how well they are integrated. Whatever your choice, the VP gear is slick.
Cheers
Les
