Discover
Posted: Sat Dec 24, 2011 8:50 am Post subject: Spark Plugs - Fine Wire Safety Warning |
I've been looking for reasons why my plane isn't as fast as it used to be. Maybe I found something.
I found a MSB concerning fine wire plug failures from Tornado Alley turbo:
http://www.taturbo.com/TATSR22-SB11-05%20fine%20wire%20spark%20plugs%20initial%20release%20sept%2023%202011.pdf
Beechtalk has a thread on this issue where they mention that NA or Normally aspirated engines have the same failure with fine wire plugs.
http://www.beechtalk.com/forums/viewtopic.php?f=37&t=59668&hilit=fine+wire
In addition, Tempests' new advertising campaign lists acceptable resistance of spark plugs as :
500 - 3000 ohms = New - Good
500 - 5000 ohms = Used - Good
So I pulled my Champion REM38S fine wires to look for broken ceramic and measured resistance:
No broken ceramic but resistance was very high.
Plug Resistance k-ohms
Cyl Top Bottom Bottom
1 29.8 68.9 Oily
2 No Continuity 2.8 Dry
3 5.7 5.9 Oily
4 12.9 33.7 Oily
Spare 19.16 Spare was removed becaused it kept fouling
If Tempest resistance values apply to Champion plugs then all my plugs are bad One plug had no continuity at all. Resistance measured while cold ~ 35 deg F.
The engine used to bust right off, starting first blade. Last year or so of flying it was hard to start and would misfire when loading up, ie when keeping WOT and lowering RPM
all pointing to a possible igniton problem.
New plugs going in. Hope to be flying again next week and we'll see how it does with new plugs....and a straight cowling....
Ned
teamgrumman(at)yahoo.com Guest
Posted: Sat Dec 24, 2011 9:40 am Post subject: Spark Plugs - Fine Wire Safety Warning |
I always use 37BY plugs.
Sent: Saturday, December 24, 2011 8:48 AM
Subject: Spark Plugs - Fine Wire Safety Warning
1 29.8 68.9 Oily
3 5.7 5.9 Oily
4 12.9 33.7 Oily
Ned
Posted: Sat Dec 24, 2011 9:44 am Post subject: Spark Plugs - Fine Wire Safety Warning |
what engine is in the SR-22?
I think the change to RHB29E is a guess. Plug runs cooler. I don't think they know the failure mode.
If the SR-22 has angle valves, well, it's an entirely different animal.
Subject: TeamGrumman-List: Spark Plugs - Fine Wire Safety Warning
1 29.8 68.9 Oily
3 5.7 5.9 Oily
4 12.9 33.7 Oily
Ned
[quote]www.homebuilthelp.com[/url]llow" target="_blank" href="http://www.matronics.com/Navigator?TeamGrum="_blank" href="http://www.matronics.com/contribution">http://www.matro====================
n2_narcosis(at)yahoo.com Guest
Posted: Mon Dec 26, 2011 8:04 pm Post subject: Spark Plugs - Fine Wire Safety Warning |
io-550.
On Sat, Dec 24, 2011 11:42 AM CST Gary Vogt wrote:
| Quote: | what engine is in the SR-22?
turbo:
of spark plugs as :
>=5000
ohms = No Good-Hard Starting-Misfire-Poor Combustion
ref.: http://www.electroair.net/pdf/SparkPlugCard.pdf
Cyl
Top
Bottom Bottom
68.9
Oily
2 No
Continuity
2.8
Dry
5.7 5.9 Oily
4 12.9 33.7
Oily
F.
does with new plugs....and a straight========================
flyv35b(at)minetfiber.com Guest
Posted: Tue Dec 27, 2011 6:39 am Post subject: Spark Plugs - Fine Wire Safety Warning |
On 12/24/2011 9:42 AM, Gary Vogt wrote:
The NA engine in the SR22 is an IO-550N, rated at 310 hp (9.0:1 CR).
This was turbo-normalized by TAT (via STC) and then later on the factory
installed a TSIO-550K, rated at 315 hp in the SR22T.
I think the failure mode is pretty well defined. The problems are
largely with the turbo-normalized engines but have also occurred on the
NA engines, both have 9.0:1 CR and a different combustion chamber than
any parallel valve Lycoming engine.
TAT issued a SB in late September which applies to the turbo-normalized
STC engine with the fine wire RHB32S spark plugs. The problems pointed
to cracked or damaged insulators which led to pre-ignition and some
engine failures. NA IO-55N engines typically had RHB32E massive
electrode plugs installed and the turbo-normalized engine typically had
the fine wire RHB32S plugs. No cracked insulators were found with the
massive electrode plugs.
TAT is recommending in SB 11-05 that the fine wire plugs be replaced in
the turbo-normalized STC'd engine with RHB29E plugs or RHB32E plugs if
the former cannot be found. The SB has much more info but here are some
excerpts.
TAT SB 11-05
"A number of field reports, at least two incidents (on airport forced
landings), and one (non-injury) accident
have prompted this service bulletin. The field reports are supported by
photographic and physical parts
evidence, and by direct experience. Collectively, this data documents an
unusually frequent occurrence of
cracked ceramic insulators found in Champion RHB32S fine wire spark
plugs installed in a variety of aircraft.
Champion RHB32S fine wire plugs were installed as original equipment in
most, but not all, turbonormalized
SR 22 aircraft (TN SR22). The same failure mode for the cracking of
RHB32S fine wire spark plugs has also
been observed in normally aspirated SR22 aircraft, a Columbia 400, a
normally aspirated Bonanza, and a
Cessna T310R.
Cracked and damaged ceramic insulators on spark plugs are known to be a
common cause of pre-ignition type
combustion events in aircraft piston engines. Pre-ignition combustion
events are the most destructive
combustion process known to affect piston engines. So far as is known,
similar issues with RHB32E (massive
style) are not occurring.
TAT has neither seen nor heard of any report of any cracked RHB32E
massive spark plug in that group of aircraft equipped with RHB32E
massive spark plugs."
I don't believe that Grumman owners have anything to worry about in our
Lycoming engines. I have been running them in my O-320 for quite some
time now as they came with the engine and have had no problems but I
don't think I would buy them due to the extremely high cost and I don't
see the added benefit. I'd rather replace the massive electrode plugs
twice as often or so. If you feel you have a fouling issue you can use
the REM37BY plugs which are less susceptible.
Cliff
Cliff
Discover
Posted: Tue Dec 27, 2011 8:59 am Post subject: Spark Plugs - Fine Wire Safety Warning |
[quote]Here are 3 references to spark plug resistance limits
One says 5,000
one says 10,000
one says 20,000
From John Schwaner
http://www.sacskyranch.com/eng174.htm
Worn or fouled spark plugs (spark plugs with over 10,000 ohm resistance, 1,000 ohm normal) can dramatically raise the voltage required to fire the spark plug
Hmm, found this from our AYA Tech guy
http://www.aircraftowner.com/magazine/tag/Aircraft%20Maintenance%20Restoration
Jeff Simon:
Champion and Unison will not release official values for a bad plug resistance, but I was told unofficially that any plug showing 20K Ohms or more should really be scrapped
Tempest says above 5,000 Ohms is bad
benlowther(at)yahoo.com Guest
Posted: Tue Dec 27, 2011 10:14 am Post subject: Spark Plugs - Fine Wire Safety Warning |
See Champion Service Letter
To: Cliff <flyv35b(at)minetfiber.com>
Sent: Tuesday, December 27, 2011 5:55 PM
Subject: Re: Spark Plugs - Fine Wire Safety Warning
--> TeamGrumman-List message posted by: 923te <923te(at)att.net (923te(at)att.net)>
Cliff
You have any experience with spark plug resistance? All my Champion fine wires were over 5000 ohms. Tempest says over 5000 and expect problems like I have been experiencing
Engine has been hard to start at least it hasn't started quickly like it used to and when loading up it misses. I hope to be flying soon to check this out. I've replaced the fine wires with some massives I had that have good resistance checks
Ned
On Dec 27, 2011, at 8:37 AM, flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)> wrote:
| Quote: | --> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
> *From:* 923te <923te(at)att.net (923te(at)att.net)>
> *To:* teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
> *Sent:* Saturday, December 24, 2011 8:48 AM
> *Subject:* Spark Plugs - Fine Wire Safety Warning
The NA engine in the SR22 is an IO-550N, rated at 310 hp (9.0:1 CR). This was turbo-normalized by TAT (via STC) and then later on the factory installed a TSIO-550K, rated at 315 hp in the SR22T.
I think the failure mode is pretty well defined. The problems are largely with the turbo-normalized engines but have also occurred on the NA engines, both have 9.0:1 CR and a different combustion chamber than any parallel valve Lycoming engine.
TAT issued a SB in late September which applies to the turbo-normalized STC engine with the fine wire RHB32S spark plugs. The problems pointed to cracked or damaged insulators which led to pre-ignition and some engine failures. NA IO-55N engines typically had RHB32E massive electrode plugs installed and the turbo-normalized engine typically had the fine wire RHB32S plugs. No cracked insulators were found with the massive electrode plugs.
TAT is recommending in SB 11-05 that the fine wire plugs be replaced in the turbo-normalized STC'd engine with RHB29E plugs or RHB32E plugs if the former cannot be found. The SB has much more info but here are some excerpts.
TAT SB 11-05
"A number of field reports, at least two incidents (on airport forced landings), and one (non-injury) accident
have prompted this service bulletin. The field reports are supported by photographic and physical parts
evidence, and by direct experience. Collectively, this data documents an unusually frequent occurrence of
cracked ceramic insulators found in Champion RHB32S fine wire spark plugs installed in a variety of aircraft.
Champion RHB32S fine wire plugs were installed as original equipment in most, but not all, turbonormalized
SR 22 aircraft (TN SR22). The same failure mode for the cracking of RHB32S fine wire spark plugs has also
been observed in normally aspirated SR22 aircraft, a Columbia 400, a normally aspirated Bonanza, and a
Cessna T310R.
Cracked and damaged ceramic insulators on spark plugs are known to be a common cause of pre-ignition type
combustion events in aircraft piston engines. Pre-ignition combustion events are the most destructive
combustion process known to affect piston engines. So far as is known, similar issues with RHB32E (massive
massive spark plug in that group of aircraft equipped with RHB32E massive spark plugs."
I don't believe that Grumman owners have anything to worry about in our Lycoming engines. I have been running them in my O-320 for quite some time now as they came with the engine and have had no problems but I don't think I would buy them due to the extremely high cost and I don't see the added benefit. I'd rather replace the massive electrode plugs twice as often or so. If you feel you have a fouling issue you can use the REM37BY plugs which are less susceptible.
Cliff
Cliff
tp://www.matronics.com/contribution" target="_blank">http://www.matronics -Matt Dralle, List Admin.bsp; --> http://www.matronics.com/Navigator?TeamGrumman-Lista href="http://forums.matronics.com" = --> <a href="http://www.matronics.com/contribution" target=====
 Download |
| Filename: |
Champion-Fine-Wire-Spark-Plug-Service-Letter.pdf |
138.68 KB |
| Downloaded: |
4169 Time(s) |
Posted: Tue Dec 27, 2011 10:15 am Post subject: Spark Plugs - Fine Wire Safety Warning |
On 12/27/2011 8:55 AM, 923te wrote:
Cliff
Ned
Not with the fine wire plugs. But I would think the manufacturer's
recommendation would trump others.
I've tested massive electrode ones some and just checked 8 used ones out
of a Tiger that showed a little over 1000 ohms, except for one that was
misfiring and failed to fire at higher air pressures on a plug testing
machine. It's resistance was was high at about 14 megohms! As I recall
all the plugs that I know were firing OK have had pretty low resistance,
like 2K or less.
I do know it is very important to have a good contact with the meter
probes on the electrodes down inside the on the center electrode. You
can get fooled if you are not carefull. Probably need to bead blast the
plug before checking the resistance. Obviously, a plug with high
resistance will make it more difficult for the mag to fire it and all
the other system resistances will be additive. And of course the
voltage the mag can generate is a factor and probably decreases some
over it's life.
Cliff
Discover
Posted: Tue Dec 27, 2011 11:16 am Post subject: Spark Plugs - Fine Wire Safety Warning |
On Dec 27, 2011, at 12:11 PM, Ben Lowther <benlowther(at)yahoo.com (benlowther(at)yahoo.com)> wrote:
[quote]See Champion Service Letter
To: Cliff <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
--> TeamGrumman-List message posted by: 923te <[url=mailto:923te(at)att.net]923te(at)att.net (923te(at)att.net)[/url]>
Cliff
Ned
On Dec 27, 2011, at 8:37 AM, flyv35b <[url=mailto:flyv35b(at)minetfiber.com]flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)[/url]> wrote:
| Quote: | --> TeamGrumman-List message posted by: flyv35b <[url=mailto:flyv35b(at)minetfiber.com]flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)[/url]>
> *From:* 923te <[url=mailto:923te(at)att.net]923te(at)att.net (923te(at)att.net)[/url]>
> *To:* [url=mailto:teamgrumman-list(at)matronics.com]teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)[/url]
> *Subject:* TeamGrumman-List: Spark Plugs - Fine Wire Safety Warning
TAT SB 11-05
Cessna T310R.
Cliff
Cliff
[url=http://www.matronics.com/contribution][/url]
<Champion-Fine-Wire-Spark-Plug-Service-Letter.pdf>
Discover
Which one there are many
Care to give a link?
Cliff
Ned
TAT SB 11-05
Cessna T310R.
Cliff
Cliff
Posted: Tue Dec 27, 2011 12:11 pm Post subject: Spark Plugs - Fine Wire Safety Warning |
My appology I attached a PDF copy, but apparently it didn't attach.
The link is: http://www.championaerospace.com/assets/Champion-Fine-Wire-Spark-Plug-Service-Letter.pdf
To: "teamgrumman-list(at)matronics.com" <teamgrumman-list(at)matronics.com>
Sent: Tuesday, December 27, 2011 8:14 PM
Cliff
Ned
TAT SB 11-05
Cessna T310R.
Cliff
Cliff
= * AeroElectric www.homman-List" rel="nofollow" target="_blank">http://www.matronics.com/Navirums.matronics.com" rel="nofollow" target="_blank">http://forums.matron--> [b]
Posted: Tue Dec 27, 2011 12:55 pm Post subject: Spark Plugs - Fine Wire Safety Warning |
On 12/27/2011 12:07 PM, Ben Lowther wrote:
Seems like everyone wants to blame someone else for the problem!
