jay(at)horriblehyde.com Guest
Posted: Thu Dec 22, 2011 2:11 am Post subject: Headphone squeal |
I’m busy trying to solve a problem of a load squeal in the headphones. The installation was done by somebody else and I’m picking up the pieces J
The system uses a Flightcom 403 intercom and has pilot, copilot and 2 pax places. I see that both the headphone and microphone wires are run in the same shielded cable (a 3 core cable). Whenever you plug a headset into any of the pax places you get an almost immediate squeal in all the ‘phones. Sometimes it does not start immediately, but as soon as you tap or try to speak into the microphone the squeal starts. Best practice suggests that the microphone and headphones wire should be separate and shielded so I suspect that this may be where the problem lies.
Anybody else had similar problems?
Jay
Posted: Thu Dec 22, 2011 6:47 am Post subject: Headphone squeal |
On 12/22/2011 04:07 AM, Jay Hyde wrote: | Quote: | <![endif]--> <![endif]-->
Jay
| To eliminate the easy stuff first:
Are the all headphones on or off the heads of the users? If any headset is plugged in but *not* properly installed on a head, you can get a positive-feedback squeal as soon as you excite the system by speaking into or tapping on a mic.
I wouldn't claim that it's impossible for the wire to cause the problem, but look at the cable attached to the headphones.
Posted: Thu Dec 22, 2011 7:03 am Post subject: Headphone squeal |
My copilot station pops and breaks squelch when there isn't a head between the mic and earpieces. The noise from the vent or heater kicks it off so I unplug the mic jack when I'm flying solo.....
Someone else mentioned something similar to this - so I'm chiming in too.....
berkut13(at)berkut13.com Guest
Posted: Thu Dec 22, 2011 7:15 am Post subject: Headphone squeal |
One 3-conductor shielded cable for both mic and phone? How are the grounds (collar) for each plug isolated from each other as well as from airframe ground?
I think you are barking up the right tree. If the system is not wired as the intercom manufacturer suggests, that’s the first place to start.
-James
Sent: Thursday, December 22, 2011 8:43 AM
Subject: Re: Headphone squeal
On 12/22/2011 04:07 AM, Jay Hyde wrote: [quote]
Jay
tim2542(at)sbcglobal.net Guest
Posted: Thu Dec 22, 2011 7:35 am Post subject: Headphone squeal |
On 12/22/2011 2:07 AM, Jay Hyde wrote: | Quote: | <![endif]--> <![endif]-->
Jay
Jay; from what I have read about this, putting mic & phone audio inside the same shielded cable will almost guarantee what you are seeing. If you go to PSE's site, ( http://www.ps-engineering.com/support.shtml )
they have a Power Point file on how to wire an audio panel. Lots of other tips & tricks on the ppt also.
[quote] [b]
Posted: Thu Dec 22, 2011 8:19 am Post subject: Headphone squeal |
I received a response from Flightcom, “If a mono headset is plugged into the intercom or a stereo headset that is set to mono, this will cause the squeal. Or if the wiring is not shielded cable, and the mic and headphone wires are in the same cable”
So it seems that I am barking up the right tree (at least in terms of the wires- not sure that I get the mono/ stereo thing, especially since their system is mono…) , which is what I thought; but thanks for the inputs. I am going to re-wire the system and will give you feedback when done.
Jay
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim Andres
Sent: 22 December 2011 05:33 PM
Jay
| Quote: | | -- Please Support Your Lists This Month nbsp; (And Get Some AWESOME FREE November is the Annual List Fund Raiser. Click below to find out more Free Incentive Gifts AeroElectric www.aeroelectric.com<www.buildersbooks.comwww.homebuilthelp.comhttp://www.matronics.com/Navigator?AeroElectric-List[/url][/b] - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] |
deej(at)deej.net Guest
Posted: Thu Dec 22, 2011 9:21 am Post subject: Headphone squeal |
On 12/22/2011 11:16 AM, Jay Hyde wrote:
| Quote: | Or if the wiring is not shielded cable, and the mic and
I'm a bit confused by this. Aren't the mic and headphone wires in the
same cable on the headphone itself (ie, the cable that goes between the
headphone and the plugs)?
-Dj
email(at)jaredyates.com Guest
Posted: Thu Dec 22, 2011 3:20 pm Post subject: Headphone squeal |
I would suggest barking up the mono/stereo tree. I have installed this intercom and I added a stereo/mono switch at each station, per the directions. I can send you a pdf of the install manual if you need it. I can produce a squeal in my system by operating that switch incorrectly.
On Dec 22, 2011, at 11:16, "Jay Hyde" <jay(at)horriblehyde.com (jay(at)horriblehyde.com)> wrote:
Jay
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim Andres
Jay
" face="courier new,courier">www.aeroelectric.com
| Quote: | www.buildersbooks.com
uilthelp.com
matronics.com/contribution
st">http://www.matronics.com/Navigator?AeroElectric-List
cs.com
michael.phil(at)ca.rr.com Guest
Posted: Fri Dec 23, 2011 12:11 am Post subject: Headphone squeal |
Check for insulation washer on mic jack
On Dec 22, 2011, at 2:07 AM, "Jay Hyde" <jay(at)horriblehyde.com (jay(at)horriblehyde.com)> wrote:
Jay
ctric.com
uilthelp.com
cs.com
