Joined: 28 Mar 2008 Posts: 1975 Location: Riley TWP Michigan
Posted: Sat Dec 17, 2011 12:47 pm Post subject: Starter contactors |
My aircraft has a Rotax 912ULS engine with an 18 amp alternator. I am considering adding lighting and additional avionics that would load the alternator to near maximum. In an effort to conserve electricity, I am thinking about eliminating the main battery contactor similar to Z-17 or Z-20. I am not familiar with the internal workings of the starter motor, but do not believe there is an internal solenoid that could be used to open the circuit. My options are:
1. Leave the circuit as is with a battery contactor.
2. Remove the battery contactor and add a second starter contactor in series with the existing one. The starter contactors would be energized by two side by side momentary push button switches.
3. Remove the battery contactor and connect the starter contactor directly to the battery.
Option 3 is the simplest and lightest weight and least expensive. But I am concerned about the starter contacts welding themselves shut with no way to shut off the power.
Is the likelihood of the starter contactor failing closed, great enough to warrant the use of two contactors in series with the starter motor?
Joe
_________________ Joe Gores |
jan_de_jong(at)casema.nl Guest
Posted: Sat Dec 17, 2011 2:05 pm Post subject: Starter contactors |
Joe,
There may be an option 4.
You might investigate using Tyco BDS-A as the battery contactor (attached).
Buy at Allied.
Plug and contacts at http://www.newunitedracetech.com
Somewhat expensive.
Search "AMP 184046".
Altogether say $60.
Jan de Jong
 Download |
| Filename: |
130-C.pdf |
214.65 KB |
| Downloaded: |
1124 Time(s) |
Posted: Sat Dec 17, 2011 3:12 pm Post subject: Re: Starter contactors |
Jan de Jong,
Thanks for that information. A latching relay has another failure mode to consider: failure to unlatch. However a latching relay may be suitable for use in some situations. I will keep it in mind.
Thanks for the link.
Joe
klehman(at)albedo.net Guest
Posted: Sat Dec 17, 2011 4:13 pm Post subject: Starter contactors |
There is also the option of a manual battery switch. Could be used as a
battery contactor substitute or just in series with the starter. Saw one
the other day that only weighed a couple of oz. It was under $10. and
rated for 200 amps.
Ken
On 17/12/2011 5:01 PM, Jan de Jong wrote:
| Quote: | Joe,
Buy at Allied.
Somewhat expensive.
Altogether say $60.
Jan de Jong
*Truncated!*
wtmills
Posted: Sat Dec 17, 2011 7:09 pm Post subject: Starter contactors |
I've considered the "Little Switch" on this page: http://www.flamingriver.com/batterydisconnect
SF bay area
Thinking Onex
On Sat, Dec 17, 2011 at 12:47 PM, user9253 <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)> wrote:
[quote] --> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=361107#361107[b]
Posted: Sun Dec 18, 2011 5:20 am Post subject: Starter contactors |
A solid state loadswitch as starter contactor could also be an option
(attached).
I would be inclined to make my own though by parallelling some BTS555.
Jan de Jong
 Download |
| Filename: |
SS1-EXP.C.pdf |
240.93 KB |
| Downloaded: |
1203 Time(s) |
Posted: Sun Dec 18, 2011 7:53 am Post subject: Starter contactors |
At 02:47 PM 12/17/2011, you wrote:
Can you share your load analysis with us?
| Quote: | Option 3 is the simplest and lightest weight and least
Not if you can climb out quickly and disconnect the battery
without undue hazard. But the incidences of sticking starter
contactors of the S704 variety are exceedingly rare.
How about a battery switch and S704-1 style starter
contactor.
When you say your alternator is loaded to "near max" . . .
under what conditions and for how long? Keep in mind
that legacy design goals for engine driven power sources
is to keep 20-25% of alternator capacity in reserve
for battery replenishment.
A load analysis of ENERGY requirements for various
phases of flight might yield some less stressing
facts about your night flight capabilities . . .
ESPECIALLY with LED nav lights. Landing lights are
a toss up . . . their current demand is high but
the duty cycle can be exceedingly low. You don't
really NEED light until you're in the flare.
Posted: Sun Dec 18, 2011 1:24 pm Post subject: Re: Starter contactors |
| Quote: | | Can you share your load analysis with us? |
Aircraft load at present time
0.3A SL 40 com
1.6A GTX 327 X-PNDR
0.2A 496 GPS
1.5A Dynon D-180 EFIS
2.6A Autopilot w/ 2 servos
0.1A Intercom
0.5A Misc
0.7A Battery Contactor
1.5A Fuel Pump (continuous)
9A Total
3.5A Proposed Dynon SkyView (additional 1.5A during backup battery charging)
3.2A Proposed 35W HID Landing light (continuous for collision avoidance)
15.7A New Total
The voltage regulator requires dedicated cooling at higher loads.
The Rotax 912ULS starts so quickly that main battery charging load is negligible. The autopilot will not be turned on until after climbing to cruise altitude. The battery will be charged by then.
I never fly at night, thus no position lights.
The electric fuel pump runs continuously per Van's RV-12 design.
| Quote: | | How about a battery switch and S704-1 style starter contactor. |
I assume that you meant to type S702-1 starter contactor. I am reluctant to use a manual battery disconnect switch. It would add another failure point to the electrical system. In the event of a failed closed contactor, it would take me a minute or more to exit the plane and operate the battery switch. The cost to buy a second starter contactor is not much more than a quality manual battery switch.
| Quote: | | But the incidences of sticking starter contactors . . . are exceedingly rare. |
That answers my question.
If it is not a safety of flight issue, I am inclined to keep the electrical system simple with one starter contactor connected directly to the battery and add an indicator light showing starter energized.
Thanks Bob, for the reply.
Joe
Posted: Mon Dec 19, 2011 7:01 am Post subject: Starter contactors |
Just a point of information.
According to Rotax 914 installation manual:
starter relay, 75 A, 300 A for 1 s, weighs 145 g (that is 5 ounces) and
requires a fuse of 2 A.
Having 2, if required, would not be so bad.
Jan de Jong
Posted: Mon Dec 19, 2011 9:28 am Post subject: Starter contactors |
Yes
That's one of the risks mitigated by the dual
feed endurance bus.
Yes
feed endurance bus. Having a manually operated
battery switch adds no new risks beyond those offere
by the legacy battery master contactor.
Where is your battery located with respect to pilot
access to a battery switch. What are your thoughts
about battery disconnect before unplanned arrival
with the earth?
Here's another thought. If all of your electro-whizzies
could be operated through a 7.5A or less fuse, then
you could consider dispensing with the main bus entirely
in favor of a 'super battery bus'. This would require that
every device have it's own ON/OFF switch . . . with
appropriate attention to shut-down-by-checklist to make
sure the battery is available the next time you go
flying. The starter contactor could be located next
to the battery also.
Posted: Mon Dec 19, 2011 2:09 pm Post subject: Re: Starter contactors |
The battery is located on the engine side of the firewall. It can be reached through the oil-check door.
I plan to use an automotive 20 or 30 amp relay in place of the master battery contactor. However, starting current would not go through the relay.
The starter contactor is located close to the battery. My only concern is a failed closed starter contactor. But that seems to be a remote possibility. And if it ever happened, it would occur while on the ground.
Thanks for all of the ideas and suggestions.
Joe
Posted: Mon Dec 19, 2011 6:12 pm Post subject: Re: Starter contactors |
I had a great idea. Wire two starter contactors in series. They will be energized by two momentary push button switches, one labeled and in plain sight on the panel, the other switch hidden. When the barefoot bandit attempts to steal my plane, he will turn on the master and push the start button. He will hear one contactor pull in and assume there is an electrical problem because the engine does not crank. So he will go find another plane that someone left the key in.
I will not need a key or an expensive key switch because only I will know how to start the engine (along with everyone else on Aeroelectric). And I will not have to worry about losing the key or forgetting it. Has anyone ever driven all of the way to the airport, only to realize the aircraft key was still at home?
Joe
Posted: Tue Dec 20, 2011 2:04 am Post subject: Starter contactors |
Hi Joe,
| Quote: | I had a great idea. Wire two starter contactors in series. They will be energized by two momentary push button switches, one labeled and in plain sight on the panel, the other switch hidden. When the barefoot bandit attempts to steal my plane, he will turn on the master and push the start button. He will hear one contactor pull in and assume there is an electrical problem because the engine does not crank. So he will go find another plane that someone left the key in.
Joe
Interesting.
1. You may need three pushbuttons (or more hands): two switches that
individually should not work (test) and a third that operates both relays.
2. Light weight Rotax relays (if procured from Rotax) may not be cheap.
Jan de Jong
Posted: Tue Dec 20, 2011 9:18 am Post subject: Starter contactors |
Joe
I hope no aircraft thief reads this, or he will look out for your other switch...
Coudn’t resist..
Good idea!
Carlos
DO NOT ARCHIVE
[quote] --
Float Flyr
Posted: Tue Dec 20, 2011 5:34 pm Post subject: Starter contactors |
Many aircraft do not have any keys. Even aircraft down to the size of the
venerable DHC beaver. Of course if you steal one of those you better know
what you are doing.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
JLuckey(at)pacbell.net Guest
Posted: Tue Dec 20, 2011 6:12 pm Post subject: Starter contactors |
Save your money for the second solenoid - Just wire your 2 pushbuttons in
series for the solenoid coil.
