n223rv(at)wolflakeairport Guest
Posted: Tue May 30, 2006 6:02 pm Post subject: RV-10 Longitudinal Level |
What is the longitudinal level line in the RV-10? Is it the bottom of the door opening where the main longeron's are, or is it the longerons that are in the tail cone section? Mine seem to be about 1.7 degrees different.
I could not seem to find anything in the plans. Thanks
-Mike
Tim(at)MyRV10.com Guest
Posted: Tue May 30, 2006 6:37 pm Post subject: RV-10 Longitudinal Level |
It's the main longeron under the door area...a little below the door.
Mike Kraus wrote:
| Quote: | What is the longitudinal level line in the RV-10? Is it the bottom of
different.
-Mike
