msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Dec 06, 2011 7:51 pm Post subject: Window Glue |
Here is my original write-up that Kelley referred to......
41.73 KB |
9562 Time(s) |
44.55 KB |
9562 Time(s) |
48.27 KB |
9562 Time(s) |
36.66 KB |
9562 Time(s) |
42.04 KB |
9562 Time(s) |
sean(at)stephensville.com Guest
kearney
Posted: Wed Dec 07, 2011 8:34 am Post subject: Window Glue |
Michael
The post and the links are greatly appreciated.
For clarity, how many tubes are require each side, door and main window.
Cheers
Les
On 2011-12-06, at 8:47 PM, "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> wrote:
[quote] Here is my original write-up that Kelley referred to......
msausen
Posted: Wed Dec 07, 2011 9:07 am Post subject: Window Glue |
It's been a while and I only used it on the doors so far but I would budget one kit for each side window and probably 2-3 for the windshield just to be safe. Someone else may have a better recollection. I did the side windows with Weldon and I was in such a rush that I forgot to put the spacers in and had the windows much too low so now there is a transition down to them. Really wish I had the Lord stuff for those.
Michael
aerosport1
Posted: Wed Dec 07, 2011 11:45 am Post subject: Window Glue |
Lord says that a 50ml cartridge will do 4.5 feet at 1/4" bead. I would buy
the 200ML and get 2 of them.
200 ml will do 19 ft. Rear windows are about 6.5 feet circumference fronts a
little more. The Windshield
is about the same as the door windows.
Order 4 extra mixing tips. This is also good for gluing the canopy top to
the fuse at the door
Frame area.
Geoff
Geoff Combs
Aerosport
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-8659p
614-834-5230f
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
rv10free2fly(at)yahoo.com Guest
Posted: Wed Dec 07, 2011 4:38 pm Post subject: Window Glue |
Geoff, I'm struggling to track down the Lord urethane adhesive here in South Australia, could you please indicate if its retailed through a specific agency or alternatively, would you consider supplying it to builders?
Patrick Pulis
Adelaide
South Australia
From: Geoff Combs <g.combs(at)aerosportmodeling.com>
Sent: Thursday, 8 December 2011 6:12 AM
Subject: RE: RV10-List: FW: Window Glue
--> RV10-List message posted by: "Geoff Combs" <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
Frame area.
Geoff
Geoff Combs
Aerosport
614-834-8659p
614-834-5230f
aerosport1
Posted: Wed Dec 07, 2011 6:04 pm Post subject: Window Glue |
I am considering selling it to builders.
I will know here by the end of the week.
Geoff
Sent from my iPhone Geoff
On Dec 7, 2011, at 7:34 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
[quote]Geoff, I'm struggling to track down the Lord urethane adhesive here in South Australia, could you please indicate if its retailed through a specific agency or alternatively, would you consider supplying it to builders?
Patrick Pulis
Adelaide
South Australia
From: Geoff Combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
Subject: RE: FW: Window Glue
--> RV10-List message posted by: "Geoff Combs" <[url=mailto:g.combs(at)aerosportmodeling.com]g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)[/url]>
Frame area.
Geoff
Geoff Combs
Aerosport
614-834-8659p
614-834-5230f
RV-10 QB N829GW
Flying 500 hrs
40033 |
aerosport1
Posted: Tue Jan 10, 2012 3:23 pm Post subject: Re: Window Glue |
I would like to let everyone know that Aerosport Products will be
stocking the Lord 7545 A/E urethane adhesive for gluing in the windows.
I will over it in a packaged kit of 3 200ML cartridges and 3 extra tips for
$130.00 plus shipping. You can by separate 200ML cartriges for $45.00.
3 packages should be plenty to do all windows and a little more. Extra tips will be 1.75 each.
I will also have to dispensing guns available for rent for $10.00.
This adhesive is also good for glueing the cabin top door frame to the
aluminum fuselage. It will be available thru direct order only no online
ordering at this time. We have material in stock
Geoff
RV-10 QB N829GW
Flying 500 hrs
40033 |
