Detaching the Fuel Tank
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
genie(at)swissmail.org
PostPosted: Mon Nov 28, 2011 1:37 pm    Post subject: Detaching the Fuel Tank Reply with quote
Does anyone know how I can detach or remove the fuel tanks from the
wings? I unscrewed the screws on the wing but the tank refuses to budge.
Due to a fuel leak I need to remove the starboard tank. Fuel was
dripping from the trailing edge of the wing root.
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
Site Admin
PostPosted: Mon Nov 28, 2011 2:12 pm    Post subject: Detaching the Fuel Tank Reply with quote
At 01:34 PM 11/28/2011 Monday, you wrote:
Does anyone know how I can detach or remove the fuel tanks from the wings? I unscrewed the screws on the wing but the tank refuses to budge.
Due to a fuel leak I need to remove the starboard tank. Fuel was dripping from the trailing edge of the wing root.
Thanks.
George Nielsen
RV-6 PH-XGN
Hi George,
I think there might be a hand full of AN3 bolts that you'll have to remove from the aft side of the spar before you can drop the fuel tank. On the RV-8, there were a lot of bolts. A lot. I can't remember if the -6/-4 have the same arrangement, but it would stand to reason.
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 18 Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
info(at)bigskymartialarts
PostPosted: Mon Nov 28, 2011 2:14 pm    Post subject: Detaching the Fuel Tank Reply with quote
Took mine off a couple of months ago, just have to wiggle it the sheet metal
pinches down on the inner metal, make sure you have the fuel lines, fuel
sending wires disconnected, and the wing to fuselage trim metal off.
John Paul
RV-6 N91CM
HCRV6(at)comcast.net
PostPosted: Mon Nov 28, 2011 5:24 pm    Post subject: Detaching the Fuel Tank Reply with quote
Remove the wing to fuselage fairing and remove the single AN-5 bolt in the tank to fuselage fitting at the front of the inboard tank rib, plus all fuel lines and tank sender electrical leads, Then just wiggle and pull. It takes some effort to lift the dimples in the tank skins out of their countersinks.
Harry Crosby
RV-6 N16CX, 913 hours
To: rv6-list(at)matronics.com
Sent: Monday, November 28, 2011 1:34:00 PM
Subject: Detaching the Fuel Tank
--> RV6-List message posted by: George Nielsen <genie(at)swissmail.org>
Thanks.
George Nielsen
RV-6 PH-XGsp; &===
hlbartel(at)pld.com
PostPosted: Mon Nov 28, 2011 5:39 pm    Post subject: Detaching the Fuel Tank Reply with quote
After you remove all screws from the upper and lower surface, you must also remove the AN3 bolt at the wing root, where it attaches to the fuselage.  Fuel line needs removed, and after carefully sliding the tank forward, you should be able to roll the tank (leading edge up) and turn the outboard end aft, and remove the wire to the fuel sending unit.
Good Luck,
Harry Bartel
On Mon, Nov 28, 2011 at 3:34 PM, George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)> wrote:
[quote]--> RV6-List message posted by: George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)>
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherla======================9;s Terrific Free Incentive Gifts provided
    * The Builder's Bookstore www.buildersbooks.com
s.com/contribution" target="_blank">http://www.matronics.com/contribution
                             -Matt Dralle, Li===========================================
_-=          - The RV6-List Email Forum -
-List" target="_blank">http://www.matronics.com/Navigator?RV6-List==========================================
http://forums.m======================   -Matt Dralle, List Admin.
ceengland(at)bellsouth.ne
PostPosted: Mon Nov 28, 2011 5:43 pm    Post subject: Detaching the Fuel Tank Reply with quote
I used 'popsicle' sticks (available at craft stores) to hold the tank flanges off the spar while pulling it off; it helps keep the skin dimples from scratching the spar flange.
On my -4, I had to pull the fuel line back into the fuselage so the root end of the tank could be pulled forward.
Charlie
On 11/28/2011 07:21 PM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote: [quote] p { margin: 0; } Remove the wing to fuselage fairing and remove the single AN-5 bolt in the tank to fuselage fitting at the front of the inboard tank rib, plus all fuel lines and tank sender electrical leads, Then just wiggle and pull. It takes some effort to lift the dimples in the tank skins out of their countersinks.
Harry Crosby
From: "George Nielsen" <genie(at)swissmail.org> (genie(at)swissmail.org)
To: rv6-list(at)matronics.com (rv6-list(at)matronics.com)
--> RV6-List message posted by: George Nielsen <genie(at)swissmail.org> (genie(at)swissmail.org)
Thanks.
George Nielsen
RV-6 PH-XGsp; &===
rv6(at)att.net
PostPosted: Mon Nov 28, 2011 7:45 pm    Post subject: Detaching the Fuel Tank Reply with quote
I have removed both tanks on my RV6 and it was definitely difficult. One tank came off eventually using the wiggle and pull technique, but the other wouldn't come off. I think some proseal was holding it on. I took a small "L" shapped pry bar( about 12") and put a piece of rubber hose on the small end. I put a piece of aluminum against the spar face to pry against and put the hose end of the bar between the spar face and tank baffle. After prying GENTLY it forced the tank forward and freed it loose.
Jerry Calvert
RV6
Edmond OK
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Monday, November 28, 2011 7:41 PM
Subject: Re: Detaching the Fuel Tank
Charlie
Harry Crosby
Thanks.
George Nielsen
RV-6 PH-XGsp; &===
<www.buildersbooks.comwww.homebuilthelp.comhttp://www.matronics=================[/b][/quote]http://forums.matronics.com[/url] - List Contribution Web generous nbsp;   --> http://www.matronics.com/c=[/b] [b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
