rv10flyer(at)verizon.net Guest
Posted: Sat Nov 19, 2011 7:05 pm Post subject: Brake Master Cylinder |
Anyone have a problem with the master cylinder leaking from the top? Is there an "O" ring you can buy at Spruce, or better yet, McMasterCarr? Or do you have to rebuild the whole thing? Thanks Pascal
9 hours and counting.... yeah...
dlm34077(at)q.com Guest
Posted: Sat Nov 19, 2011 7:34 pm Post subject: Brake Master Cylinder |
Matco has the rebuild kits
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of preid
Sent: Saturday, November 19, 2011 6:47 PM
Subject: Brake Master Cylinder
0123456789012345678901234
effectus(at)rogers.com Guest
Posted: Sun Nov 20, 2011 12:14 pm Post subject: Brake Master Cylinder |
Pried,
I have seen where the top of the master cylinder
gets grit/dirt in the
depression on top where it can get down along the
shaft and ruin the seal.
There is no boot on this set-up to keep dirt away
from the piston/shaft.
Dave Hertner
On 11/19/2011 8:47 PM, preid wrote:
| Quote: | Anyone have a problem with the master cylinder
Thanks Pascal
Checked by AVG - www.avg.com <http://www.avg.com>
- Release Date: 11/19/11
*Dave Hertner*
*President*
*Dial-2-Start *
*Cellular Remote Switches*
*www.dial2start.com*
*Effectus AeroProducts Inc.***
*Kit Aircraft Component Manufacturing
Machining - Fabrication - Laser/Water-Jet Cutting*
*Email: davehertner(at)effectus-aeroproducts.com
<mailto:davehertner(at)effectus-aeroproducts.com>*
*Blog: kitaircraftmods.com
<http://www.kitaircraftmods.com/>***
*Phone: (519) 933-2055*
