ralphmariafinch(at)gmail. Guest
Posted: Mon Nov 14, 2011 10:04 pm Post subject: Question about ADS-B In/Out and Transponders |
Assume I want ADS-B In and Out capability. In a new build--no legacy equipment--can I install ONLY a UAT on 978 MHz? or do I still need to also install at least a Mode-C transponder (1090 MHz)?
Posted: Mon Nov 14, 2011 11:04 pm Post subject: Question about ADS-B In/Out and Transponders |
FAR 91.215 says you have to have a transponder. Maybe that will change some day, but they've got a few years.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Mon, Nov 14, 2011 at 9:57 PM, Ralph Finch <ralphmariafinch(at)gmail.com (ralphmariafinch(at)gmail.com)> wrote:
[quote] Assume I want ADS-B In and Out capability. In a new build--no legacy equipment--can I install ONLY a UAT on 978 MHz? or do I still need to also install at least a Mode-C transponder (1090 MHz)?
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
| [b]
BobsV35B(at)aol.com Guest
Posted: Tue Nov 15, 2011 7:42 am Post subject: Question about ADS-B In/Out and Transponders |
Good Morning Dave,
It might be more accurate to say: "FAR 91.215 tells you where you have to have a transponder."
The vast majority of the air space within the USA and below ten thousand feet MSL does NOT require a transponder to be installed.
As Always, It All Depends!
Happy Skies,
Old Bob
In a message dated 11/15/2011 1:05:23 A.M. Central Standard Time, dave.saylor.aircrafters(at)gmail.com writes:
| Quote: | FAR 91.215 says you have to have a transponder. Maybe that will change some day, but they've got a few years.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Posted: Tue Nov 15, 2011 9:28 am Post subject: Question about ADS-B In/Out and Transponders |
(at)Old Bob: true enough…I should have phrased my question:
Assume I want ADS-B In and Out capability AND want to fly in Class C and D airspace. In a new build--no legacy equipment--can I install ONLY a UAT on 978 MHz? or do I still need to also install at least a Mode-C transponder (1090 MHz)?
Then I think the answer is, I need a Mode-C transponder and UAT; or, Mode-S transponder, and ADS-B receiver.
Correct?
RF
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Tuesday, November 15, 2011 7:37 AM
Subject: Re: Question about ADS-B In/Out and Transponders
Good Morning Dave,
Happy Skies,
Old Bob
In a message dated 11/15/2011 1:05:23 A.M. Central Standard Time, dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com) writes:
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Posted: Tue Nov 15, 2011 9:55 am Post subject: Question about ADS-B In/Out and Transponders |
Good Afternoon RF,
That one is beyond my sphere of knowledge, though I THINK you are correct. I have not studied the requirements for the UAT or ADS-B in or out.
As an aside, I know I will install nothing in my airplane that is not required to be installed by current regulations. If I could get by with it, I would NOT install an ELT of either type nor a transponder of any sort.
My experience has been that by the time mandatory devices are required to be installed, they generally have substantially reduced prices and contain better and more reliable components.
The very first 64 code transponders were over 14 thousand bucks. And that was back when you could buy a Bonanza for about the same price.
After the airlines and corporate airplanes bought those, Wilcox came out with one for only 7 grand. By the time we little guys were forced to install them if we wanted to fly IFR in busy airspace, they were up to over one thousand codes and priced under a thousand bucks. Plus, they were smaller, lighter, and used less power.
I think it pays to wait.
Happy Skies,
Old Bob
In a message dated 11/15/2011 11:29:45 A.M. Central Standard Time, ralphmariafinch(at)gmail.com writes:
Correct?
RF
Posted: Tue Nov 15, 2011 10:38 am Post subject: Question about ADS-B In/Out and Transponders |
Very true Old Bob! I too will wait until the latest possible moment to buy and install the goodies. But, I am installing antennas now, while the fuselage is easy to get at, and am anticipating what antennas might be needed. I've decided to put in both a 1090 MHz transponder antenna and a 978 MHz UAT antenna; if I'm wrong, little time and money lost. Thanks for your input.
RF
On Tue, Nov 15, 2011 at 9:52 AM, <BobsV35B(at)aol.com (BobsV35B(at)aol.com)> wrote:
[quote] Good Afternoon RF,
Happy Skies,
Old Bob
Posted: Tue Nov 15, 2011 10:58 am Post subject: Question about ADS-B In/Out and Transponders |
Sounds good to Me!
Happy Skies,
Old Bob
In a message dated 11/15/2011 12:39:34 P.M. Central Standard Time, ralphmariafinch(at)gmail.com writes:
| Quote: | Very true Old Bob! I too will wait until the latest possible moment to buy and install the goodies. But, I am installing antennas now, while the fuselage is easy to get at, and am anticipating what antennas might be needed. I've decided to put in both a 1090 MHz transponder antenna and a 978 MHz UAT antenna; if I'm wrong, little time and money lost. Thanks for your input.
RF
| Quote: | Good Afternoon RF,
Happy Skies,
Old Bob
