Navworx... d-sub uses sliding lock retainer / screw lock
hotwheels
PostPosted: Fri Nov 11, 2011 7:19 am    Post subject: Navworx... d-sub uses sliding lock retainer / screw lock Reply with quote
If you're using Navworx ADS600B, you should note that the DB37 comes with an unusual connector arrangement consisting of posts and sliding lock retainer (see page 15 of attached pdf). I have never seen one of these before and was stumped on how exactly to get it attached. Note that the screws on the plug have tiny ridges that lock onto the retainer. The posts are mounted on the box. It's all very obvious once you see it work, but not so much when you're handed a pile of parts.
Jay
ITT-Cannon-d sub acc update.pdf
ITT Canon d-sub descriptions
 Filename:  ITT-Cannon-d sub acc update.pdf
 Filesize:  1.49 MB
 Downloaded:  339 Time(s)
BobsV35B(at)aol.com
PostPosted: Fri Nov 11, 2011 8:16 am    Post subject: Navworx... d-sub uses sliding lock retainer / screw lock Reply with quote
Good Morning Jay,
Those retainers are heavily used on many older Bendix-King components. I love them. Easy to fasten and easy to unfasten yet they hold very well. Just on opinion! <G>
Happy Skies,
Old Bob
In a message dated 11/11/2011 9:23:42 A.M. Central Standard Time, jaybrinkmeyer(at)yahoo.com writes:
--> AeroElectric-List message posted by: "jayb" <jaybrinkmeyer(at)yahoo.com>
Jay
http://forums.matronics.com/viewtopic.php?p=357516#357516
http://forums.matronics.com//files/itt_cannon_d_sub_acc_update_20 bsp; (And Get Some AWESOME FREE o find ifts bsp; lder's LP you for ; -Matt Dralle, List = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
