Yak-18T light bulb replacement LED? Strobes?
thomasg(at)infosysnetwork
PostPosted: Sun Nov 06, 2011 7:38 am    Post subject: Yak-18T light bulb replacement LED? Strobes? Reply with quote
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Warren Hill
Sent: Monday, June 13, 2011 9:43 AM
To: yak-list(at)matronics.com
Subject: Re: Re: Yak-18T light bulb replacement LED? Strobes?
Here is what I have done and is from a previous posting.
The red beacon at the top of my vertical stabilizer and the wing tip nav /position / strobes on my CJ are from AveoEngineering. They are LED-based, very bright, draw next to no power and will probably last forever as they are in solid epoxy. You'll have to make a small aluminum plate to cover the large hole each the wing tip, but that's very simple. Here is a link:
www.aveoengineering.com/Aviation/Airplane_LED_Lights/position_LED_lights/AveoFlashLP_Ultra/index.php
www.aveoengineering.com/Aviation/Airplane_LED_Lights/position_LED_lights/PosiStrobe_MiniMax/index.php
Two of us at FFZ have AveoEngineering lights on our CJs.
There are also replacements for the small exterior Chinese bulb. It's 24 volt, LED cluster that has the same bayonet base. This would be a direct, drop-in replacement for the lights on the nose gear, mains and tail cone. This particular LED arrangement has viewing angle of 90 degrees, so it is brightest when seen from straight ahead. Here is where I found this:
www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fother_bulbs.htm
The web site navigation is a little confusing, but basically what you would be looking for is the 24 volt, white, dual contact, single intensity, 15 mm 1142 bayonet base. The ordering designation is: 1142-W15-24V White LED bulb - 24V. I've attached a picture of what this looks like installed.
There are also smaller LEDs from the same web site that you can use to replace the six interior landing gear indicator lights and the cockpit interior lights.
I hope that this is helpful.
Warren Hill
On Jun 13, 2011, at 1:15 AM, Qttudine wrote:
--> Yak-List message posted by: "Qttudine" <tangforums(at)hotmail.com (tangforums(at)hotmail.com)>
Find a more professional lighting online store, contact the customer service, maybe they will tell you in detail.
help me eliminate the dark and my fear.
http://forums.matronics.com/viewtopic.php?p=342847#342847
- The Yak-List -->   &n========================<b   -     &nbs -->="=======================<br">
 Filesize:  270.78 KB
 Viewed:  1570 Time(s)
