cjhukill(at)cox.net Guest
Posted: Sun Oct 30, 2011 5:26 am Post subject: Recreational pilot |
When I built my RV-8 ten years ago, I had an engine built that produced 210 HP, but was limited by placards to 180 for the purpose of qualifying it to be flown under the Recreational pilots license. Back then AOPA was trying to get the Feds to allow that class of pilot to operate under the medical self certification exemption that is allowed for sport pilots, glider and balloon pilots. The restrictions back then would also require a fixed pitch prop, so I put one of those on as well.
The Feds didn't go for it then, but said they would re-evaluate after the Sport pilots exemption has been in effect for about ten years. Well in the last ten years, there has been zero medical deficiency caused accidents for sport pilots. Now, again the EAA and AOPA lawyers are submitting to the FAA an exemption to allow the Rec pilots to self certify. The aircraft requirements would once again allow for a max of 180HP, but not a restriction for fixed pitch prop. The 2 seat restriction is also removed, and replaced with "one Passenger". So my question is...How does the RV10 perform with the reduced payload of 1 pax and 180HP? It would be interesting to experiment with a flying RV10 that was limited by how far in you push the throttle to see if it would be practical to placard your engine instruments to allow you to operate under those conditions without a medical. Even if the Feds required modifications to your IO540 to physically limit you to 180, at what altitude? The rules would require you to operate under 10,000 msl, but you could probably still pull 180HP at that altitude with your downrated motor. And you could still have the other 80 HP available for emergencies down low. A pilot with a medical could simply remove whatever limiting devise is require (placards) and fly it like a normal RV10. It would be nice to have that flexibility and would open your machine up to a whole other class (market) of pilots.
Chris Hukill
bhughes(at)qnsi.net Guest
Posted: Sun Oct 30, 2011 8:30 am Post subject: Recreational pilot |
Chris,
I would expect a climb rate of 600-700 fpm at 180 HP with fwf weight equal to the io 540. Lighter fwf may make the rear baggage area worthless.
Bobby
On Oct 30, 2011, at 8:37 AM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
| Quote: | When I built my RV-8 ten years ago, I had an engine built that produced 210 HP, but was limited by placards to 180 for the purpose of qualifying it to be flown under the Recreational pilots license. Back then AOPA was trying to get the Feds to allow that class of pilot to operate under the medical self certification exemption that is allowed for sport pilots, glider and balloon pilots. The restrictions back then would also require a fixed pitch prop, so I put one of those on as well.
Chris Hukill
Kelly McMullen
Posted: Sun Oct 30, 2011 1:15 pm Post subject: Recreational pilot |
I would expect the FAA to place the same stringent requirements on a qualifying aircraft as they do for Light Sport. That is that from certification forward it must have met the requirements of the category at all times. In other words they don't let you go back and forth between categories. Hard to say if they would place a gross wt limit on the category...don't recall if there ever was one. There are some numbers that Vans has for the prototype with Continental IO-360 engine as to performance. I don't believe that engine has ever been derated below 195hp.
On Sun, Oct 30, 2011 at 9:21 AM, Bobby J. Hughes <bhughes(at)qnsi.net (bhughes(at)qnsi.net)> wrote:
| Quote: | Chris,
Bobby
#avg_ls_inline_popup{position:absolute;z-index:9999;padding:0px;margin:0px;overflow:hidden;wordWrap:break-word;color:black;font-size:10px;text-align:left;line-height:130%;}#avg_ls_inline_popup div{border-width:3px;border-style:solid;padding:3px;padding-left:8px;padding-right:8px;-moz-border-radius:5px;-webkit-border-radius:5px;}#avg_ls_inline_popup .red{border-color:#D20003;;background-color:#F5D4C1;;}#avg_ls_inline_popup .orange{border-color:#F57301;;background-color:#FFD3B0;;}#avg_ls_inline_popup .yellow{border-color:#EAA500;;background-color:#FEEFAE;;}#avg_ls_inline_popup .green{border-color:#00A120;;background-color:#C3E5CA;;}
A&P/IA, EAA Tech Counselor
KCHD |
davidsoutpost(at)comcast. Guest
Posted: Sun Oct 30, 2011 2:48 pm Post subject: Recreational pilot |
There is also a maximum 130 knot limitation.
David Clifford
RV-10 Builder
Howell, MI
To: "RV10 post msg" <rv10-list(at)matronics.com>
Sent: Sunday, October 30, 2011 9:22:01 AM
Subject: Recreational pilot
Chris Hukill
Bob Turner
Posted: Sun Oct 30, 2011 7:59 pm Post subject: Re: Recreational pilot |
I don't recall any speed limitations for recreational pilots. There is one for Sport Pilots.
The FAR wording says the aircraft must not have been certificated for more than 2 seats. So I don't think you can go back and forth between a "regular" RV-10 (4 seats) and a "recreational" one. You have to declare the number of seats when you get your A/W inspection. Once in writing, it's not easy to change.
_________________ Bob Turner
RV-10 QB |
Bob Turner
Posted: Sun Oct 30, 2011 8:05 pm Post subject: Re: Recreational pilot |
Ignore my last comment. I see that you say the FAA has changed the wording from 2 seats to one passenger. Is this done, or a proposal?
RV-10 QB |
Posted: Sun Oct 30, 2011 9:32 pm Post subject: Recreational pilot |
Not to put too fine a point on it but... I think one would end up with an expensive, heavy, underpowered aircraft that has minimal resale potential.
Robin
richard.beebe(at)yale.edu Guest
Posted: Fri Nov 04, 2011 6:41 am Post subject: Recreational pilot |
No, this is a different animal. They're not talking about adding another
category of aircraft. And actually there's some confusion in the
original message. It doesn't just apply to pilots with Recreational
licenses.
EAA and FAA are going to submit, in January, a proposal to the FAA that
would let pilots flying recreationally to self-certify. Under the
proposed exemption, pilots holding recreational, private, commercial, or
airline transport pilot certificates who only fly recreationally could
use the same driver’s license medical self-certification standard
currently available to sport pilots. The limitations would be that the
plane has to have 180hp or less, fixed gear, max 4 seats, in daylight
VFR, with up to one passenger. The pilot will have to take and pass an
on-online course that shows they understand the ramifications of
self-certification (it'll be similar to the ADIZ course in size and
difficulty I think). You'll get a card to carry that shows you've passed.
The specs on the aircraft were derived from the limitations imposed on
Rec pilots as that's something the FAA is comfortable with.
Since the proposal hasn't been submitted yet, the details could, of
course, change.
--Rick
On 10/30/2011 5:09 PM, Kelly McMullen wrote:
| Quote: | I would expect the FAA to place the same stringent requirements on a
below 195hp.
Kelly McMullen
Posted: Fri Nov 04, 2011 6:58 am Post subject: Recreational pilot |
Hi Rick,
I understand that the EAA and AOPA are wanting to define it as a set
of rules that apply to a pilot. Odds are very strong that the FAA will
want to apply it to a set of aircraft qualifying requirements, because
that is much easier for them to draw the line in the sand. (inspectors
can more easily determine if an airplane conforms than if a pilot
does) I was under the impression that the request had been submitted.
Otherwise, why all the press hoopla for a non-submittal?
Kelly
On Fri, Nov 4, 2011 at 7:37 AM, Rick Beebe <richard.beebe(at)yale.edu> wrote:
category of aircraft. And actually there's some confusion in the original
message. It doesn't just apply to pilots with Recreational licenses.
would let pilots flying recreationally to self-certify. Under the proposed
exemption, pilots holding recreational, private, commercial, or airline
transport pilot certificates who only fly recreationally could use the same
driver’s license medical self-certification standard currently available to
sport pilots. The limitations would be that the plane has to have 180hp or
less, fixed gear, max 4 seats, in daylight VFR, with up to one passenger.
The pilot will have to take and pass an on-online course that shows they
understand the ramifications of self-certification (it'll be similar to the
ADIZ course in size and difficulty I think). You'll get a card to carry that
The specs on the aircraft were derived from the limitations imposed on Rec
Since the proposal hasn't been submitted yet, the details could, of course,
change.
--Rick
KCHD |
Posted: Mon Nov 07, 2011 6:32 am Post subject: Recreational pilot |
I think because they wanted a "big announcement" at AOPA Summit. They're
still working out the legalese of the proposal and they're waiting until
after the elections. Word I have is that it will be submitted in January.
--Rick
On 11/04/2011 10:55 AM, Kelly McMullen wrote:
Hi Rick,
Kelly
