dlm34077(at)q.com Guest
Posted: Mon Oct 31, 2011 6:57 am Post subject: N968TP |
Anyone know about this?
| Quote: | | Report created 10/31/2011 Record 6 ********************************************************************************** IDENTIFICATION Regis#: 968TP Make/Model: EXP Description: VANS RV10 Date: 10/30/2011 Time: 1514 Event Type: Incident Highest Injury: Minor Mid Air: N Missing: N Damage: Unknown ******************************************************************************** | 0 | Quote: | | ******************************************************************************** | 1 | Quote: | | ******************************************************************************** | 2 | Quote: | | ******************************************************************************** | 3 | Quote: | | ******************************************************************************** | 4 | Quote: | | ******************************************************************************** | 5 | Quote: | | ******************************************************************************** | 6 | Quote: | | ******************************************************************************** | 7 | Quote: | | ******************************************************************************** | 8 | Quote: | | ******************************************************************************** | 901234567
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Oct 31, 2011 9:17 am Post subject: Re: N968TP |
Can't seem to find any news reports about this. Strange.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon Oct 31, 2011 10:08 am Post subject: N968TP |
I see it was certified on 4/2011 low serial number 40031. I found nothing
too.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Mon Oct 31, 2011 10:24 am Post subject: N968TP |
Pilot or owner of 968TP listed in FAA records as TORELLO FORTUNATO TACCHI of
Jacksonville FL with Private ASEL/S, instrument and IA. Crash site is about
30-40 miles north of Jacksonville. Airworthiness and registration are listed
as 4/2011
philperry9(at)gmail.com Guest
Posted: Mon Oct 31, 2011 10:52 am Post subject: N968TP |
I found some notes that indicate the aircraft has been flying since 2006/7ish.
Also found that it had an air boat engine that was overhauled by the owner back around that time frame.
VAF was the source of both.
as 4/2011
Posted: Tue Nov 01, 2011 9:54 am Post subject: N968TP |
Sounds like fuel exhaustion.....
"The plane, out of Hilliard, was reportedly returning from Waycross when it ran out of fuel, clipped some trees and flipped into a hay field near the edge of Folkston."
http://www.charltoncountyherald.com/articles/2011/11/02/news/doc4eb00f9f0f36c342285798.txt
On Mon, Oct 31, 2011 at 9:50 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
| Quote: | | Report created 10/31/2011 Record 6 ********************************************************************************** IDENTIFICATION Regis#: 968TP Make/Model: EXP Description: VANS RV10 Date: 10/30/2011 Time: 1514 Event Type: Incident Highest Injury: Minor Mid Air: N Missing: N Damage: Unknown ******************************************************************************** | 0 | Quote: | | ******************************************************************************** | 1 | Quote: | | ******************************************************************************** | 2 | Quote: | | ******************************************************************************** | 3 | Quote: | | ******************************************************************************** | 4 | Quote: | | ******************************************************************************** | 5 | Quote: | | ******************************************************************************** | 6 | Quote: | | ******************************************************************************** | 7 | Quote: | | ******************************************************************************** | 8 | Quote: | | ******************************************************************************** | 9 012 34 56 7
8
robin(at)PaintTheWeb.com Guest
Posted: Tue Nov 01, 2011 10:01 am Post subject: N968TP |
Light plane crashes in Folkston field
Published:
Tuesday, November 1, 2011 11:46 AM EDT
Some Charlton County cows got a surprise on Sunday morning when a small plane crashed into a field they were grazing.
The pilot was able to make his way out of the crushed aircraft and then walk nearly half-a-mile to Hwy. 121 where he was picked up by a passing motorist and transported to Charlton Memorial Hospital where he was treated.
Charlton County Sheriff Dobie Conner said the incident was reported to his department around 1 p.m. on Sunday, but the actual crash occurred earlier in the morning. The pilot was the lone occupant of the plane and no one on the ground ��� not even a cow ��� was injured.
The FAA was called in to investigate the incident.
75.73 KB |
10867 Time(s) |
rv10rob(at)gmail.com Guest
Posted: Tue Nov 01, 2011 12:05 pm Post subject: N968TP |
So is that the 5th RV-10 hull loss now?
On Tue, Nov 1, 2011 at 10:59 AM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Published:
Â
Â
Tim Olson
Posted: Tue Nov 01, 2011 12:26 pm Post subject: N968TP |
I think it's more than that...
We've had:
The Dan Lloyd Incident
The IFR incident
The possibly Medical incident
The inflight fire
The post-landing fire
The out-of-gas (this one)
.. and I'm not positive if the others were hull losses but I know there
were at least a couple others, one being the V-8 I think that pancaked
in (not sure if they got it flying again?), and another one that was
a botched landing that punched the gear up through. Off the top of my
head I can't remember if that's it or not. At least I *think* the
hull losses are less than you can count on 2 hands.
Tim
On 11/1/2011 3:02 PM, Rob Kochman wrote:
| Quote: | So is that the 5th RV-10 hull loss now?
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Bob Turner
Posted: Tue Nov 01, 2011 12:32 pm Post subject: Re: N968TP |
More than that. By my count:
3 fatals: auto engine failure/botched corn field landing
improper IMC
Probable in flight heart attack
non-fatal: auto engine/fire on the ground
in flight fire-fuel connection loose- may not be total loss
crash in OH 28 Sept 2011 cause unknown
this one.
_________________ Bob Turner
RV-10 QB |
aerosport1
Posted: Tue Nov 01, 2011 12:37 pm Post subject: N968TP |
Tim is correct with the accidents. I think it is 6 total losses so far.
Geoff Combs
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
arplnplt(at)gmail.com Guest
Posted: Tue Nov 01, 2011 12:38 pm Post subject: N968TP |
What about the one just before this one with the guy from Texas taking delivery? Did we ever find out what the cause was on that one?
Dave Leikam
On Nov 1, 2011, at 3:23 PM, Tim Olson wrote:
We've had:
The IFR incident
The inflight fire
... and I'm not positive if the others were hull losses but I know there
Tim
> Rob Kochman
> Woodinville, WA
rleffler
Posted: Tue Nov 01, 2011 12:39 pm Post subject: N968TP |
, one being the V-8 I think that pancaked in (not sure if they got it flying again?)
It was repaired and flew into OSH 2 years ago.
bob
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
jcumins(at)jcis.net Guest
Posted: Tue Nov 01, 2011 12:41 pm Post subject: N968TP |
Yes, the bad part it could have been avoided completely. There is no excuse for running out of gas when flying over the US. There is a airport just about every 50 miles.
Â
This is a total shame and just drives everyones insurance rate higher, due to bad decisions.
John Cumins
40864, wing top skins moving forward.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Tuesday, November 01, 2011 1:02 PM
Subject: Re: Re: N968TP
Published:
Bob Turner
Posted: Tue Nov 01, 2011 1:04 pm Post subject: Re: N968TP |
"What about the one just before this one with the guy from Texas taking delivery? Did we ever find out what the cause was on that one?"
This was the Ohio crash. Per VAF the pilots are now both out of the hospital although the builder was seriously burned. The builder has posted on VAF his condition but has not said anything about the cause. Curiously, it also is not listed on the NTSB web site yet.
As to running out of gas, this certainly is very poor judgement. Although, until the facts are in, we don't know. Maybe there was a serious undetected fuel leak. I will say, though, that some pilots are type A personalities. The owner of this latest accident aircraft has previously posted on VAF about his (illegal) experimentation with car gas in a certified airplane.
RV-10 QB |
Posted: Tue Nov 01, 2011 1:31 pm Post subject: N968TP |
On 11/1/2011 4:32 PM, Bob Turner wrote:
improper IMC
This one may be being rebuilt in Melbourne, FL.
Linn
Posted: Tue Nov 01, 2011 1:39 pm Post subject: N968TP |
Man people are stupid. Auto fuel in a certified plane, yes there are stc's
for them, but not many really do not work out well. I have helped recover
many a plane in Alaska out in the bush due to auto fuel for one reason or
another. And when auto fuel burns it is very hard to see the flame when it
is small and it's flash point is so much lower than 100LL.
You would never catch me using auto fuel in any airplane.
Bob yes I agree with you the story is not complete and that there could have
been a fuel leak causing the plane to run out sooner than expected or very
fast, but that's not the usual case.
Bob another thing that might need to be brought up is the quality of the
flares people are making on their own. I have seen so many flares that were
not made correctly and over flared or the flare was not deep enough. This
the leaks found in the Vans airplane is way too high. I am not sure if it
is a training issue on how to make tubing flares correctly or is it the
cheap soft tubing that vans supplies.
I will be for sure using 5052 tubing in my -10, yes it is much stiffer and
much harder to work with but it is much stronger and less likely to crack.
So the real question is?? Is the leak rates that are being found due to
material issues or craftsman quality of making the tubing??
Just my thoughts.
John Cumins
President
707-425-7100
707-425-7576 Fax
jdriggs49(at)msn.com Guest
Posted: Tue Nov 01, 2011 1:47 pm Post subject: N968TP |
Did you count the one from several years ago from Lebanon, TN that crashed in south Alabama in IMC??
[quote] Date: Tue, 1 Nov 2011 17:28:31 -0400
--> RV10-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net>
> --> RV10-List message posted by: "Bob Turner"<bobturner(at)alum.rpi.edu>
> improper IMC
Linn
> this one.
> Bob Turner
> RV-10 QB
> http://forums.matronics.com/viewtopic.php?p=356577#356577
amekler
Posted: Tue Nov 01, 2011 3:13 pm Post subject: N968TP |
Tim,
What do you think these accidents/incidents will do to our insurance rates? Is the Rv-10 rate higher than other comparable planes?
Alan
N668G
