What fuel pressure should I see for electric or engine fuel
Ray.R.Doerr(at)sprint.com
PostPosted: Mon May 22, 2006 11:10 am    Post subject: What fuel pressure should I see for electric or engine fuel Reply with quote
The real problem for the low fuel pressure was the Dynon Sensor
Type was set to 1 (Carb Version) instead of 2 (Injected Version). Once
I changed this to 2, it is now reading 17.5 PSI at idle.
Thank You
Ray Doerr
40250
