Horizontal Stabilizer Riveting
pioneer(at)choiceonemail.
PostPosted: Wed May 24, 2006 6:00 am    Post subject: Horizontal Stabilizer Riveting Reply with quote
When I cleco the horizontal stabilizer together with just the leading edge ribs and the plywood form blocks there is a lot of stress on the ribs to the point where the HS is somewhat distorted.  Has anyone done anything additional before putting in the rivets on the leading edge ribs?  I am concerned about the airfoil shape.  I was thinking of pro-sealing the leading edge ribs in place with the the main spar clecoed in and then going back and riveting in the leading edge ribs after the pro-seal has dried and I can remove the main spar.
Bruce Case #40446
LIKE2LOOP(at)aol.com
PostPosted: Wed May 24, 2006 4:13 pm    Post subject: Horizontal Stabilizer Riveting Reply with quote
In a message dated 5/24/06 10:02:58 A.M. Eastern Daylight Time, pioneer(at)choiceonemail.com writes:
     i held the skins together at the trailing edge with rubber tipped spring clamps a foot or two away from where i was rivetting. This kept them from bending wide open and kept the skin in close contact to the tip ribs, be careful to not crease the metal with hard clamps.  I need to rivet the aft spar to place and my HS is done!
Steve
Stephen Blank         RV-10 Builder #40499 / C-170B flyer
766 SE River Lane
Port St. Lucie, FL 34983
772-475-5556 cell
