samira.h(at)shaw.ca Guest
Posted: Tue Oct 11, 2011 8:40 am Post subject: How to set magneto timing by using simple tools |
Since 6 years I am using a pointy
chopstick, an elastic and a bendable
ruler to set my magnetos.
First I use the original TDC tool
(with a tight fitting o-ring installed
below the pointer pin at the top) to
find TD.
Then I jam the ruler between the half
way open vanes and outer cowling
ring. There are 28 shutters, so divide
them by 360 degrees and you have
exactly 12.86 degrees between 2 vanes.
I affix the pointy chopstick to the propeller
using the elastic, are you still with me?
The TDC tool shows the piston has reached TD,
I move the ruler so the chopstick points
on zero. Then I pull the prop further until
the TDC tool pointer starts to move again,
now I have the dwell factor and just divide
it by 2, indicating the exact TDC on the ruler.
Now I look at the embossed pre-setting number
on my magneto (e.g. 23 degrees), subtract
this number from the pre-ignition angle with
fully advanced flyweights (e.g. 31 or 27 degrees,
depends on your engine), multiply it by the
gear ratio, in my case 0.787 and set my timing.
Job done and no fancy tools involved.
If someone is interested, I could
send you a picture.
cheers
Elmar
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Tue Oct 11, 2011 9:24 am Post subject: How to set magneto timing by using simple tools |
Elmar,
I AM INTERESTED not only by pictures but by a more complete : How to time ones magneto for the DUMB (I would be the dumb OK!!!)
Tutorials on magneto.
I have done one for : How to change a tire in less than five minutes" for the dumb"....that's my level in mechanic.
But I am learning.
Pics would be great
thanks to propose
Didier Blouzard from Paris (yesss in France)
2011/10/11 Elmar Hegenauer <samira.h(at)shaw.ca (samira.h(at)shaw.ca)>
| Quote: | --> Yak-List message posted by: Elmar Hegenauer <samira.h(at)shaw.ca (samira.h(at)shaw.ca)>
find TD.
send you a picture.
cheers
Elmar
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
____________________________
Didier BLOUZARD Portable : +33 6 24 24 36 72
Email: didier.blouzard(at)gmail.com (didier.blouzard(at)anolistech.fr)
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
Posted: Tue Oct 11, 2011 10:32 am Post subject: How to set magneto timing by using simple tools |
Bonjour Didier,
the tight fitting o-ring is below
the red dot. Its applied friction
hampers the tool to turn while
you are pulling the prop. But don't
screw it in all the way, it might
disengage the pointer from the push-rod
and will get you into "Teufel's Kueche",
Dennis has been there twice.
Again, IMO the original TDC indicator is NOT
a timing setting tool but a much more precise
TDC and TDC-dwell finding contraption through
its higher push-rod to pointer ratio.
More pictures to follow the next days.
cheers
Elmar
362.42 KB |
10104 Time(s) |
Posted: Tue Oct 11, 2011 11:23 am Post subject: How to set magneto timing by using simple tools |
Setting everything in the Russian Mags is more complicated than just
getting the points to open and close at the proper time using whatever
method. Which is really all we have talked about here. That mag is one
very complicated son of a gun. Suggest you also talk to Dennis about
getting a picture he has.
The whole issue of timing ends up being a simple matter of when you
actually fire the spark plug in relationship to exactly where the piston
is on the compression stroke. Period, end of story. That is what it
all adds up to and ends up doing. BANG! Fires the air fuel mixture.
However, the variables involved here include:
1. Adjustment to the coupling adapter on the bottom of the mag.
2. Adjustment of the mag housing in relationship to the engine case.
3. Adjustment of the Mag Rotor in relationship to the mag housing.
4. Adjustment of Point Gap/breaker plate.
5. Spark Plug Gap.
All of these things impact when the spark plug actually produces the
spark.
I am not an expert on M-14 engine, or radials of any kind really. I am
just another person that is learning as he goes. That said, I have
learned that on other engines, when that spark plug fires can be a
surprise when you find out when it ACTUALLY fires, compared to when you
THOUGHT it WOULD fire.
A timing light would be nice, but I can't figure out how that would work
on a geared engine, let alone inches from the prop.
Mark
brian(at)lloyd.com Guest
Posted: Tue Oct 11, 2011 12:55 pm Post subject: How to set magneto timing by using simple tools |
On Tue, Oct 11, 2011 at 12:21 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
| Quote: | --> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
5. Spark Plug Gap.
There is an excellent treatise on the care and feeding of magneto ignition systems. While it is directed at the Bendix and Slick mags in common use on Lycoming and Continental flat engines, the theory is applicable to all magnetos.
http://www.sacskyranch.com/pubsmag.htm
I have a copy of this book and it explains things like the relationship between the E-gap angle, the points in the primary opening, distributor angle, and crank angle. Excellent reading if you really want to understand these things.
OTOH, electronic ignition simplifies all this and makes it all intuitively understandable.
spark.
You are right; setting the timing dynamically, i.e. when plug 1 fires, requires access to the crank angle or cam angle independent of the gear reduction system. But since most of our mags use fixed timing, timing the engine statically is just fine. (Housai mags use RPM-based spark advance so they have advanced all the way to 1930's technology!)
Coil-per-plug and wasted-spark systems that dispense with the distributor are SOOO much simpler.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
tigeryak18t
Posted: Tue Oct 11, 2011 2:12 pm Post subject: How to set magneto timing by using simple tools |
Soo simple but efficient.
Thanks a lot for the hint. That's a usefull one.
Thanks a lot Elmar
Didier
| Quote: | Bonjour Didier,
cheers
Elmar
French Wing |
Posted: Tue Oct 11, 2011 6:15 pm Post subject: How to set magneto timing by using simple tools |
Elmar,
Can you send a picture of where you placed the O ring. I'm soon to be needing the Device in a couple weeks as I'm rebuilding my M14P after it was FOD'd. This has been a real educational experience to say the least.
Doc
On Oct 11, 2011, at 5:09 PM, Didier Blouzard <didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)> wrote:
[quote]Soo simple but efficient.
Thanks a lot Elmar
Didier
2011/10/11 Elmar Hegenauer <[url=mailto:samira.h(at)shaw.ca]samira.h(at)shaw.ca (samira.h(at)shaw.ca)[/url]>
cheers
Elmar
Email: [url=mailto:didier.blouzard(at)gmail.com]didier.blouzard(at)gmail.com (didier.blouzard(at)anolistech.fr)[/url]
Posted: Tue Oct 11, 2011 6:22 pm Post subject: How to set magneto timing by using simple tools |
Elmar,
Never mind. Found it.
Doc
cheers
Elmar
<TDC-Fix1.jpg>
jan.mevis(at)informavia.b Guest
Posted: Tue Oct 11, 2011 10:49 pm Post subject: How to set magneto timing by using simple tools |
Soon there’ll be laser-plugs on the market. Three beams that can even be direction-controlled and fire multiple sparks at their crossing point (programmable further down!).
No more high voltage systems. It took some time to develop them (making the lasers small enough to fit in the casing of a spark plug).
As soon as mass production starts, prices will be reasonable (I hope).
You can use the mag points to trigger the electronics.
I already do that with an MSD device (Mark Bitterlich’s idea) on my M14R. I did the timing the classical way and it works well.
5 hours flown with it until now and the results are better than expected. Better combustion, much smoother run, particularly at low RPM and with a cold engine.
Further testing is still needed, but unfortunately, I’m grounded (as so many others in Europe).
BR
Jan
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Brian Lloyd
Sent: dinsdag 11 oktober 2011 22:53
To: yak-list(at)matronics.com
Subject: Re: How to set magneto timing by using simple tools
On Tue, Oct 11, 2011 at 12:21 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote: | Quote: |
5. Spark Plug Gap. |
spark.
on a geared engine, let alone inches from the prop. |
3191 Western Dr.
+1.916.877.5067 (USA) | Quote: | | http://www.matronics.com/Navigator?Yak-List | 01234567
Posted: Thu Oct 13, 2011 7:54 am Post subject: How to set magneto timing by using simple tools |
Didier and others,
here come the promised pictures.
Have fun.
cheers
Elmar
439.51 KB |
10027 Time(s) |
392.14 KB |
10027 Time(s) |
Posted: Thu Oct 13, 2011 8:17 am Post subject: How to set magneto timing by using simple tools |
Very ingenious Elmar.
For dummies like me, I bought this timing tool which works perfect,
especially if the airplane has a spinner because the spinner backing
plate covers the timing marks on the prop flange.
http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=E25
Disregard the TDC tool. Won't work properly because it is a geared engine.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 10/13/2011 10:50 AM, Elmar Hegenauer wrote:
| Quote: | Didier and others,
Have fun.
cheers
Elmar
