dalemed
Posted: Wed Oct 05, 2011 4:22 am Post subject: Taildragger CG |
I'm building a CH650 with the taildragger option. Can I expect the empty CG to be more forward, aft or the same compared to a comparable equipped nosewheel CH601/650?
I can probably calculate the difference if I had accurate weight numbers for the nosewheel assembly. I would assume the same weight for the mains, just a different moment arm.
Any info will be greatly appreciated!
_________________ Dale
Zenith Zodiac CH650 |
JohnDRead(at)aol.com Guest
Posted: Wed Oct 05, 2011 7:07 am Post subject: Taildragger CG |
The CG has nothing to do with wether an aircraft is a tail dragger or a nose wheel type. do not archive
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
Posted: Wed Oct 05, 2011 8:38 am Post subject: Taildragger CG |
You don’t think that moving the 40+ pound main gear forward a foot and eliminating the nose gear would influence the CG?
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
Sent: Wednesday, October 05, 2011 8:05 AM
Subject: Re: Taildragger CG
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
| Quote: | | http://www.matronics.com/Navigator?Zenith601-List | 01234567
jlatimer1(at)cox.net Guest
Posted: Wed Oct 05, 2011 1:05 pm Post subject: Taildragger CG |
You're also moving the main gear forward and adding a tail wheel with a long moment arm, which should offset the affects of removing the nosewheel.
Jerry
-- Craig
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
Posted: Wed Oct 05, 2011 3:01 pm Post subject: Taildragger CG |
Guys,
You are missing the point. The CG has to stay within the
design range, certainly moving or removing heavy pieces will affect the balance
of the aircraft. You will have to do what ever is necessary to bring the CG
into design range. The Zenith factory could give you guidance in this
area. do not archive.
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 10/5/2011 3:06:16 P.M. Mountain Daylight Time,
jlatimer1(at)cox.net writes:
