Aero LED'S
sam.marlow
PostPosted: Sat Oct 01, 2011 6:21 am    Post subject: Aero LED'S Reply with quote
I have 2 friends that have installed the new Aero Led Nav and strobes,
and both have noise in the headset at all times, even with the strobes
turned off. Has anyone else experienced this? I'm trying to trouble
shoot this, and don't have a clue.
PostPosted: Sat Oct 01, 2011 9:46 am    Post subject: Aero LED'S Reply with quote
At 09:17 AM 10/1/2011, you wrote:
<sam.marlow(at)roadrunner.com>
strobes, and both have noise in the headset at all times, even with
the strobes turned off. Has anyone else experienced this? I'm trying
to trouble shoot this, and don't have a clue.
Are these products qualified for type certificated
aircraft . . . i.e. are there STC's for installation
on factory machines?
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
PostPosted: Sat Oct 01, 2011 11:07 am    Post subject: Aero LED'S Reply with quote
Do I presume correctly that the noise happens with the
position lights on, strobes off but the noise disappears
with the position lights off?
(o o)
sam.marlow
PostPosted: Sun Oct 02, 2011 8:07 am    Post subject: Aero LED'S Reply with quote
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
(o o)
No, it's all the time, but worse with the strobes on. And no this is not
an STC'ed or TSO'ed product.
tiethoff
PostPosted: Sun Oct 02, 2011 9:58 am    Post subject: Aero LED'S Reply with quote
The green and the red led's are driven by a switched power supply. This gives a hum in the system. The only solution is to build a filter (choke and condensator) at the 12v input of the led's.
2011/10/2 Sam Marlow <sam.marlow(at)roadrunner.com (sam.marlow(at)roadrunner.com)>
--> AeroElectric-List message posted by: Sam Marlow <sam.marlow(at)roadrunner.com (sam.marlow(at)roadrunner.com)>
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
I have 2 friends that have installed the new Aero Led Nav and strobes, and both have noise in the headset at all times, even with the strobes turned off. Has anyone else experienced this? I'm trying to trouble shoot this, and don't have a clue.
                 (o o)
No, it's all the time, but worse with the strobes on. And no this is not an STC'ed or TSO'ed product.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Met vriendelijke groet,
Eric Tiethoff
mail: eric(at)tiethoff.nl (eric(at)tiethoff.nl)
web: http://tiethoff.nl
PostPosted: Sun Oct 02, 2011 10:03 am    Post subject: Aero LED'S Reply with quote
Do you have access to a proven 'recipe for success'
as to the size and placement of the components?
(o o)
tiethoff
PostPosted: Sun Oct 02, 2011 10:40 am    Post subject: Aero LED'S Reply with quote
The problem is that you have to use long powerlines from the main switch to the wingtips. So in the wingtips are the "transmitters" (the switched power supply's to make the led's working). These long powerlines act as an antenna and dirty-up your system. In order to surpress this transmission you have to block it with a choke (i guess 20-30 turns of 22awg wire and a condensator of 10 micro farad). See drawing...good luck.
2011/10/2 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
                  (o o)
Eric Tiethoff
 Filesize:  334.31 KB
 Viewed:  8513 Time(s)
PostPosted: Sun Oct 02, 2011 6:23 pm    Post subject: Aero LED'S Reply with quote
Electrolytic capacitors are almost never a part
of a solution for reducing attenuation at radio
frequencies. The value of inductance for what
I presume is an air-wound, helix of wire is only
useful as an attenuator at radio frequencies.
I'm not suggesting that this approach did not
work for somebody . . . they were on the right
track for a practical filter. But without knowing
the spectrum of energy for the offending noise,
this filter was far from optimal to the task.
In the instance where a filter was added to the
Buck Pucks . . . see
http://www.aeroelectric.com/Catalog/AEC/9051/9051-700A.pdf
the components were selected to attenuate radio
frequency noise reported by disappointed users
of the Buck Pucks. A hand-held transceiver held
close to an operating LED driven by a Buck Puck
was bombarded by a substantial noise sorce.
The capacitors used in this case are rather small
as is the inductor. The inductor was not selected
for it's ability to function as a high quality
resonance but as a lossy impedance. It was desirable
that any VHF+ RF appearing across the terminals
was converted to heat!
It seems likely that the AeroLED study will
produce a similar finding. But until that
finding is verified, moving forward with any
filter experiments could be a poor use of time
or offer a risk of less than optimal performance.
Bob . . . [quote][b]
berkut13(at)berkut13.com
PostPosted: Sun Oct 02, 2011 7:27 pm    Post subject: Aero LED'S Reply with quote
Yes. I have a composite aircraft and installed the units using an old
wiring diagram that came in the box - I too had lots of noise in the
headsets and radio reception.
There is a NEW wiring diagram on the website that the tech guys at AeroLEDs
pointed out...sure enough, the radio transmitted noise went away. Problem
one solved.
However, (after LOTS of hunting) the rest of the line transmitted noise was
being picked up somewhere in the XM audio output of the Garmin 396 GPS that
was being fed into the intercom. This even happened with the GPS on battery
power...it was very weird.
I tried power filters on all ends (LED end, GPS, and intercom) - no luck.
the only thing that fixed the problem was upgrading to the Garmin 496. It
seems that the audio output grounding is different on the 496 and is not
susceptible to the noise, or floating ground issue, or whatever that real
problem was.
Noise free and loving it...and the LEDs.
Hope that helps!
-James
Berkut/Race13
www.berkut13.com
