cabin cover hints
dlm46007(at)cox.net
PostPosted: Sun May 21, 2006 4:00 pm    Post subject: cabin cover hints Reply with quote
Although we modified out lid a few months ago for the shoulder harnesses, we
recently began trimming it to fit the fuselage. In our first attempt we used
a compressor and cutoff wheel that supplied only 6 CFM (at)90 PSI. This was
insufficient and resulted in cutting a distance of about 72" in about 90
mins. This morning we used a larger compressor and completed the cut to trim
lines for doors, windows, mid side flanges, rear flanges, windscreen flanges
and under door flanges. The areas were then sanded with a sanding wheel and
belt sander. This mornings work was done in two hours using a few sanding
disks and three cutoff wheels.
capsteve
PostPosted: Sun May 21, 2006 7:49 pm    Post subject: cabin cover hints Reply with quote
I threw away the friction disk after about two minutes, I found much better
success with a body air saw. Very precise cutting and 24 tooth blade didn’t
bind.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4640677249
19.00 from harbor freight. The blades last about 4feet or so, so get extras.
The other benefit is it doesn’t toss fiberdust all over the shop.
My .02
steve
