		dalemed
				 Posted: Wed Oct 05, 2011 4:22 am    Post subject: Taildragger CG |
				I'm building a CH650 with the taildragger option.  Can I expect the empty CG to be more forward, aft or the same compared to a comparable equipped nosewheel CH601/650?
 I can probably calculate the difference if I had accurate weight numbers for the nosewheel assembly.  I would assume the same weight for the mains, just a different moment arm.
 Any info will be greatly appreciated!
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Dale
Zenith Zodiac CH650 |
		JohnDRead(at)aol.com Guest
				 Posted: Wed Oct 05, 2011 7:07 am    Post subject: Taildragger CG |
				The CG has nothing to do with wether an aircraft is a tail dragger or a  nose wheel type. do not archive
  Regards,  John
 CH701 - Colorado - Jabiru 3300
 Cell: 719-494-4567
 Home:  303-648-3261
				 Posted: Wed Oct 05, 2011 8:38 am    Post subject: Taildragger CG |
				You don’t think that moving the 40+ pound main gear forward a foot and eliminating the nose gear would influence the CG?
 -- Craig
 From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
 Sent: Wednesday, October 05, 2011 8:05 AM
 Subject: Re: Taildragger CG
 Regards, John
 Cell: 719-494-4567
 Home: 303-648-3261
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Zenith601-List  | 	  01234567
		jlatimer1(at)cox.net Guest
				 Posted: Wed Oct 05, 2011 1:05 pm    Post subject: Taildragger CG |
				You're also moving the main gear forward and adding a tail wheel with a long moment arm, which should offset the affects of removing the nosewheel.
 Jerry
 -- Craig
 Regards, John
 Cell: 719-494-4567
 Home: 303-648-3261
				 Posted: Wed Oct 05, 2011 3:01 pm    Post subject: Taildragger CG |
				Guys,
             You  are missing the point. The CG has to stay within the
 design range, certainly  moving or removing heavy pieces will affect the balance
 of the aircraft. You  will have to do what ever is necessary to bring the CG
 into design range. The  Zenith factory could give you guidance in this
 area. do not archive.
 Regards,  John
 Cell: 719-494-4567
 Home:  303-648-3261
 In a message dated 10/5/2011 3:06:16 P.M. Mountain Daylight Time,
 jlatimer1(at)cox.net writes:
