Posted: Tue Sep 27, 2011 4:32 pm Post subject: % HP |
Any ideas on a formula for % horsepower that works for different size
engines? So far Google has let me down.
Linn
Discover
Posted: Tue Sep 27, 2011 5:14 pm Post subject: % HP |
Here ya go
hp = torque * RPM / 5252
otherwise check your POH cause it's different in each plane or
see attachments for O-360
121.9 KB |
4297 Time(s) |
 Download |
| Filename: |
Percent_HP.pdf |
253.71 KB |
| Downloaded: |
468 Time(s) |
 Download |
| Filename: |
3.pdf |
111.51 KB |
| Downloaded: |
581 Time(s) |
 Download |
| Filename: |
Percent_HP_2.pdf |
563.13 KB |
| Downloaded: |
590 Time(s) |
Posted: Tue Sep 27, 2011 7:36 pm Post subject: % HP |
Thanks for the replies.
I should have been a little more specific. I'm looking for a formula that computes % HP from parameters that are measurable .... fuel flow, OAT, RPM, MP etc. so I can display the value on my EFIS. Since the EFIS measures many parameters a formula could compute % HP realtime. Hard to fly and look at the graphs ...... There is a formula from Van's (below from another email) but it doesn't seem to be accurate for different size engines (not sure which engine really fits), and I don't have the math skills to tweak it. I was hoping someone might have the magic bullet.
Linn
Van's formula:
h=(H-((R-r)*(5.58-0.125*(M-m))/100 + 7.35*(M-m)) + 2.0*pa/1000)*sqrt((519-3.58*pa/1000)/(460+ta))
h% = h/H*100
where
Constants:
H= maximum sea level horsepower at maximum manifold pressure (from manufacturer’s data)
R= maximum sea level RPM at maximum manifold pressure (from manufacturer’s data)
M= maximum sea level manifold pressure at rated RPM (from manufacturer’s data)
For a Lycoming/Superior 320 (my case):
H= 160
R= 2700
M= 28.6
Variables (inputs)
r= actual RPM
m= actual manifold pressure
pa= actual pressure altitude (altimeter set to 29.92 inHg)
ta = actual air inlet temperature at pressure altitude (OAT has practically the same value)
Outputs
h = calculated horsepower
h%= calculated percent horsepower
On 9/27/2011 9:16 PM, 923te wrote: [quote] Here ya go
jamey
Posted: Tue Sep 27, 2011 10:43 pm Post subject: % HP |
Lean of peak %HP is determined by fuel flow. ROP all the other atmospheric parameters apply. A good rule of thumb for the big Continentals (IO-520/550) operated LOP is 14.9 HP per gallon per hour of fuel flow. Probably not helpful to a carbureted Lycoming. Drop a line to the GAMI guys and see if they have a suggestion. There's got to be some reasonable equation for approximating out there. Your equation doesn’t seem terrible as when I plug it into Mathematica it returns some not unreasonable looking values. Maybe a bit high.
Jamey
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Linn Walters
Sent: Tuesday, September 27, 2011 8:33 PM
Subject: Re: % HP
Linn
Van's formula:
h% = h/H*100
where
Constants:
H= 160
R= 2700
M= 28.6
Variables (inputs)
r= actual RPM
Outputs
Here ya go
Posted: Tue Sep 27, 2011 10:56 pm Post subject: % HP |
Thanks Jamey. Math is one of my weak areas. I wish I knew what the constants are and where they came from. Your suggestion about GAMI is a good one.
Linn
On 9/28/2011 2:40 AM, James Courtney wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Jamey
From: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com)] On Behalf Of Linn Walters
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Subject: Re: % HP
Linn
Van's formula:
h% = h/H*100
where
Constants:
H= 160
R= 2700
M= 28.6
Variables (inputs)
r= actual RPM
Outputs
Here ya go
Checked by AVG - www.avg.com
Version: 10.0.1410 / 09/27/11
