dave.thompson(at)verizon. Guest
Posted: Sat May 20, 2006 9:12 pm Post subject: Air tools & Compressor |
Hi Guys,
I'm building a Corvair conversion using WW's manual. After I get it running,
I plan to purchase a 601XL kit. Meanwhile, I'm tooling up.
I got a great deal on an assorted box of "Asian sheet metal air tools"; die
grinders, saws, shears, rivet guns/squeezers & stuff. Not all new or of the
best quality. I plan to take advantage of them anyway. I know they are
cheep, but If I like a tool and it breaks, I'll replace it with a high
quality one. My current air compressor is a 1 hp and needs to be upgraded.
My question is:
What CFM & HP do you guys suggest I look into for my new air compressor? The
specs are overwhelming. I've been considering a 5 HP 6.5 CFM (at) 90PSI,
120VAC, at about $300.00. Should that be enough for the tools that I'll
need? I need to install a dedicated outlet anyway so 220VAC is not an issue.
I've got a very small shop and it needs to have wheels.
Dave Thompson
dave.thompson(at)verizon.net
Posted: Sat May 20, 2006 9:27 pm Post subject: Air tools & Compressor |
This is a quote I kept from a message John Bolding sent in September of
2005:
"Actually the single stage compressors make MORE cfm at lower pressure and
will pump up FASTER to their limit of 100-125 psi (depending on pump and
pressure setting). If you don't need 175 psi, single stage compressors give
you more volume for the hp. Had to explain the above to MANY plant engineers
over my 32 yrs of selling air compressors in the industrial market.
Buy the best air compressor you can afford, it will be a tool you will use
for life. LOW &SLOW John Bolding"
-- Craig
p.mulwitz(at)worldnet.att Guest
Posted: Sun May 21, 2006 2:18 am Post subject: Air tools & Compressor |
Perhaps the type of compressor is more important than the actual
numbers. The compressors with belt drive are a lot quieter than the
ones with direct drive. The belt drive ones are also a bit more
expensive and generally have higher ratings for SCFM. I just got a
new one from Canada (Eagle brand?) with wheels that cost around $250.
Paul
XL wings
At 10:05 PM 5/20/2006, you wrote:
| Quote: | What CFM & HP do you guys suggest I look into for my new air compressor? The
taffy0687(at)yahoo.com Guest
Posted: Sun May 21, 2006 5:20 am Post subject: Air tools & Compressor |
Dave----- my compressor is a:
Sears Craftsman, 6 hp, 30 gal, 6.4 scfm(at) 90psi., 120 v. 15 amp ( all data taken off unit) and works great for the task at hand. It is an upright model. Doesn't take much room and is easy to move. Mine was about $300 and I consider it a great unit for the price-------- a little noisy when pumping up, but with the 30 gal tank it doesn't start very often.
Fritz------- Corvair, N93FL (reserved)
Dave Thompson <dave.thompson(at)verizon.net> wrote:
Hi Guys,
My question is:
Dave Thompson
Be a chatter box. Enjoy free PC-to-PC calls with Yahoo! Messenger with Voice.
stutzman(at)stutzman.com Guest
Posted: Sun May 21, 2006 8:07 am Post subject: Air tools & Compressor |
On Sun, 21 May 2006, Big Gee wrote:
| Quote: | Dave----- my compressor is a:
upright model.
1 hp (electric) = 746 watts
120 volts * 15 amp = 1800 watts.
So your compressor motor is actually only 2.4 HP. This is not surprising,
there is all sorts of weird claims when manufactures (of almost any
kind of power tool) state their horsepower.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
frank.hinde(at)hp.com Guest
Posted: Sun May 21, 2006 4:40 pm Post subject: Air tools & Compressor |
I have the sears 6hp oil free direct drive....The note about HP claims
is well put..they call it "Peak HP"...This of course is complete
nonsense there really is no such thing as "Peak HP". Anyway, mine is the
biggest 120V model they make and is probably rated around 2HP.
Having said that, it does everything I ever need...On the RV there is a
lot of work requiring the use of die grinders that use a lot of air and
this machine has never failed to keep up.
The other thing is it is an oil free machine, Oil free machines have a
reputation for wearing out fast but I wanted a mchine that I could use
for spraying paint at the end of the project. An oil free compressor is
by far the simplest way to spray paint.
Now here is the best part...I have made fresh air breathing system
feeding compressor air to the upstream side of a high quality
respirator. I took a sample of air and had it tested in our lab for
contaminants. Came out just fine and perfectly adequate to breathe.
So that is how I am spraying the cyanide laden paints.
The downside of oil free is you need to drop a drop of oil in the air
tools occasionally...But $8 for a die grinder I kind of forgot!
I'm nearing the end of the RV project and the machine is running just
fine...Solid rivets take a LOT more air than pop rivets so it bodes well
for lasting thru a zodiac project. The machine is noisy and you would be
well advised to put it in a separate room.
Frank
compressor? The specs are overwhelming. I've been considering a 5 HP
6.5 CFM (at) 90PSI, 120VAC, at about $300.00. Should that be enough for
the tools that I'll need? I need to install a dedicated outlet anyway
| Quote: | I've got a very small shop and it needs to have wheels.
dclaytx2(at)hotmail.com Guest
Posted: Sun May 21, 2006 9:16 pm Post subject: Air tools & Compressor |
Hey Dave,
I'm using a $99 air compressor I got from Harbor Freight that works great.
It has a 2.5HP motor and delivers 120PSI at 5.6CFM. The item number is
90385-4VGA. I have had absolutely no problems with the compressor or the $39
rivet gun I also purchased from Harbor Freight.
Dave Clay
Temple, TX
CH601XL Scratch builder
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
davevanlanen(at)sbcglobal Guest
Posted: Wed May 24, 2006 2:31 pm Post subject: Air tools & Compressor |
Or if you don't have a separate room, or putting the compressor outside
means you need to leave the door open in the winter months, you can build a
sound deadening box around it. I built a box with 3/4" plywood, and lined
it with Homosote on the inside. I included intake and exhaust openings
facing away from the work area. It is amazing the reduction in noise level.
I can now work with the compressor running, and have no problem with noise
level.
Dave Van Lanen
Madison, WI
601XL - Stabilizer
Time: 05:40:52 PM PST US
Subject: RE: Air tools & Compressor
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
I have the sears 6hp oil free direct drive.......
...........for lasting thru a zodiac project. The machine is noisy and you
would be
Frank
Chris Lewis
Posted: Thu May 25, 2006 5:47 am Post subject: Re: Air tools & Compressor |
You can also use a Filter Silencer like the one shown in the attachment. I got mine at Grainger and it helped quiet down my Home Depot 30 gallon unit.
Chris in Seattle
18.83 KB |
511 Time(s) |
_________________ 750/ Zen-vair Semi-Scratch Builder
N750XT (reserved) |
