Who makes this?
recapen(at)earthlink.net
PostPosted: Mon Sep 12, 2011 9:08 am    Post subject: Who makes this? Reply with quote
Yes it is a stolen picture....I think I bought it from Spruce - they don't carry it any more and I have broken mine...while lowering the plane after finishing a maintenance evolution - no damage to the plane.
I am looking to get some replacement parts....the hook broke off inside the block where it joins the larger threaded rod...also, the handle seems to be jammed on the larger threaded rod - leading me to twisting the other part off with too much force.
The hook is completely seperated...the handle is completely jammed - it will have to be cut from the crossbar in order to prevent me from buying a new crossbar also.
Any ideas or assistance welcome - it is not a critical item right now as I have finished the work I needed to do.....
Ralph
RV6A N822AR (at) N06 - 125+ hours - doing my IFR training...what a blast!
 Filesize:  65.23 KB
 Viewed:  2464 Time(s)
ceengland(at)bellsouth.ne
PostPosted: Mon Sep 12, 2011 11:01 am    Post subject: Who makes this? Reply with quote
On 09/12/2011 12:03 PM, Ralph E. Capen wrote:
body{font-size:10pt;font-family:arial,sans-serif;background-color:#ffffff;color:black;}p{margin:0px;}
Ralph
Never seen that one before, but if you are interested in a replacement, you might look at
http://www.averytools.com/prodinfo.asp?number=4665
(Relatively easy to duplicate the technique with stuff you probably have lying around the hangar.)
PostPosted: Mon Sep 12, 2011 2:12 pm    Post subject: Who makes this? Reply with quote
Thanks for the info on the different one - looks pretty neat!
Still want to find out about my original.....getting it fixed might be cheaper than starting over. Was thinking I would pick their brain as to materials etc.....
