johnryanallen(at)hotmail. Guest
Posted: Sun Sep 11, 2011 2:32 pm Post subject: Damaged Screw Heads when Attempting to Remove Fuel Tank |
use an easy out to remove the screws.
> Date: Sun, 11 Sep 2011 22:55:48 +0200
| Quote: | To: rv6-list(at)matronics.com
Subject: Damaged Screw Heads when Attempting to Remove Fuel Tank
--> RV6-List message posted by: George Nielsen <genie(at)swissmail.org>
Due to a leaky starboard fuel tank I attempted to remove a panel on
the wing some of the screws were rather tight. This resulted in
damage to the screw heads.
How can I remove the damaged screws?
Once the panel is removed, what should I do to remove the fuel tank?
Thanks.
George Nielsen
RV-6 PH-XGN&g===
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
HCRV6(at)comcast.net Guest
Posted: Sun Sep 11, 2011 2:55 pm Post subject: Damaged Screw Heads when Attempting to Remove Fuel Tank |
I have had success using a small left hand drill bit (Yes, they do make them!) and an easy out. Most of the time the damaged screw will back out when you start the reverse turning drill bit.
Harry Crosby
RV-6 N16CX, 873 hours
Sent: Sunday, September 11, 2011 1:55:48 PM
Thanks.
George Nielsen
RV-6  =
