Speedy11(at)aol.com Guest
Posted: Wed Aug 31, 2011 7:15 am Post subject: Signal splitter |
Listers,
I want to split a VHF comm signal to use two radios with one antenna. I know two radios cannot use the same antenna at the same time because one radio will be damaged. But, like the VHF nav signal splitter, I wonder if there is a splitter available that will allow only one radio to use the single antenna at a time. Can an audio panel accomplish the task?
I have a comm "splitter" that when a handheld radio cable is inserted it bypasses or disables the coax to the primary aircraft radio. I'd like something similar except that is switchable between two aircraft radios.
Stan Sutterfield
Neal.George(at)hurlburt.a Guest
Posted: Wed Aug 31, 2011 7:53 am Post subject: Signal splitter |
Stan -
It depends on your goals.
If you only want to use one radio at a time, a physical, mechanical coax
switch will do the job easily and inexpensively. Amateur radio
operators commonly use coax switches to switch one radio among multiple
antennas - works just as well the other way around.
But you if you mount a coax switch, the other radio is completely out of
the circuit - you can't talk on one and monitor the other.
I have seen adaptations of transmit/receive relays that would allow
attaching two radios to one antenna. In effect, when the operator keys
radio A, the T/R relay disconnects radio B, preventing back-feed damage.
This type of arrangement would allow you to use one radio and monitor
the other. These critters are scarce, and since it's an active device,
they tend to be expensive and temperamental.
neal
kesleyelectric(at)iowatel Guest
Posted: Wed Aug 31, 2011 8:23 am Post subject: Signal splitter |
Stan,
The comm splitter that you have is exactly what I am looking for. In case of primary radio failure, I would like to be able to disconnect the primary radio and connect the handheld into the external antenna. Do you have any information to pass along about this device.
One issue that I need to address is making sure not to activate the stick mounted PTT switch with the antenna disconnect from the primary radio. The Garmin folks say there is a high probability of damage. The simple answer would be to remember to turn the primary radio OFF if it is malfunctioning. Any and all thoughts on this matter welcome.
Tom Barter
Kesley, IA
Avid Magnum-wiring
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com
Sent: Wednesday, August 31, 2011 10:12 AM
Subject: Signal splitter
Listers,
Stan Sutterfield
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
ftyoder(at)yoderbuilt.com Guest
Posted: Wed Aug 31, 2011 1:07 pm Post subject: Signal splitter |
What plane are you flying? If it is composite the handheld should work fine; anyway, mine does.
Posted: Wed Aug 31, 2011 2:42 pm Post subject: Signal splitter |
The Magnum is a rag and tube taildragger with dimensions similar to a Super Cub. Others in similar planes have told me that their hand helds with just the rubber duckie antenna work to varying degrees, depending on range and altitude. I seem to recall a posting by Bob some time ago regarding how much improved hand held performance would be if connect to the comm antenna. If there is a simple way to accomplish this while isolating the panel mounted main radio, I would like to do it.
A few years ago at Oshkosh I listened to a NTSB investigator describe an incident with the chain of events leading to a crash with fatalities. A electrical failure on a night cross country in west Texas prevented the pilot of a 152 from turning on the lights at the last airport available before running out of fuel. (Remember, chain of events.) Had they been carrying a hand held radio, (or wired with Z13- , the outcome may have been different.
Some time ago Jim Weir published an article in Kitplanes magazine about using a mini plug and receptacle to do this, but I think there ended up being some problems with it.
Tom Barter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of F. Tim Yoder
Sent: Wednesday, August 31, 2011 4:04 PM
Subject: Re: AeroElectric-List: Signal splitter
Posted: Wed Aug 31, 2011 9:00 pm Post subject: Signal splitter |
At 10:11 AM 8/31/2011, you wrote:
| Quote: | Listers,
I have a comm "splitter" that when a handheld radio cable is inserted it bypasses or disables the coax to the primary aircraft radio. I'd like something similar except that is switchable between two aircraft radios. |
There are things called 'diplexers' that will
prevent two transmitters on the same antenna
from destroying the opposite receiver but they're
VERY expensive and I'm not sure they can be had
for a broad frequency range like the VHF comm band.
Years ago I built an adapter that might serve your
purposes. It was a combination "splitter" in the
common receive mode so both radios could listen
simultaneously. When one of the transmitters was
selected and then keyed to talk, a relay disconnected
the opposite radio from the antenna system and made
a hard connection to the comm antenna for the
transmitter in use.
That was about 30 yeara ago and hand wired. I could
probably do a much more compact version on an
etched circuit board with captive BNC connectors
Should go together a lot quicker and be smaller
too.
Bob . . . [quote][b]
Posted: Wed Aug 31, 2011 9:09 pm Post subject: Signal splitter |
Tom Barter |
We had some discussion a about the Tap-Jack
that would let a hand-held take ownership
of the ship's external VHF comm antenna.
I built one here . . .
http://aeroelectric.com/Pictures/Antenna/CommTap-Jack.jpg
. . . and bought an ICOM product to disassemble
here . . .
http://aeroelectric.com/Pictures/Antenna/ICOM_Hand_Held_Adapter_1.jpg
http://aeroelectric.com/Pictures/Antenna/ICOM_Hand_Held_Adapter_2.jpg
Two problems: (1) The ICOM product made not the slightest
pretense for maintaining feed line integrity through
the device. (2) The quality of miniature, closed circuit
phone jacks generally suck for air. I just couldn't
get excited about this gizmo as a product. I think my
recommendations at the time called for having a cable-
male to cable-female junction in the antenna feed line be
accessible in flight. You could break into the coax using
a short piece of coax off your hand-held fitted with the
appropriate connectors.
Posted: Thu Sep 01, 2011 5:58 pm Post subject: Signal splitter |
Tom,
I used the Icom box that Bob mentioned. But, after Bob's comments, you may want to not consider the Icom product. Anyway you can view my photos of it at http://www.rv-8a.net/2008.htm and scroll down to 7 Feb. I have not given it a rigorous checkout, so take Bob's comments as those of a professional.
Here is the Aircraft Spruce link to see their ad - http://www.aircraftspruce.com/catalog/avpages/icomswitchbox.php
Stan Sutterfield
In a message dated 9/1/2011 3:04:16 A.M. Eastern Daylight Time, aeroelectric-list(at)matronics.com writes:
| Quote: | The comm splitter that you have is exactly what I am looking for. In case
Tom Barter
Kesley, IA
Avid Magnum-wiring
Posted: Thu Sep 01, 2011 6:10 pm Post subject: Signal splitter |
Thanks to all for your comments and suggestions.
I'm flying a RV-8A and using one radio at a time would be fine - both radios also have a second freq monitor capability. I assumed there was some type of coax manual switch available, but I was unsure where to search.
Has anyone heard of the Narco VP-16? Another guy on the list has one for sale but I have no experience with them. Would it be suitable to safely split the signal? I'd hate to risk damaging two high dollar radios.
Stan Sutterfield
| Quote: | It depends on your goals.
neal |
Posted: Thu Sep 01, 2011 9:05 pm Post subject: Signal splitter |
At 08:54 PM 9/1/2011, you wrote:
Those miniature closed circuit jacks will probably
work as advertised for several years. I'd go for
a Switchcraft or similar product. Corrosion and
loss of contact pressure over time puts the panel
mounted radio at-risk for loss of connection to
the antenna.
Posted: Thu Sep 01, 2011 9:50 pm Post subject: Signal splitter |
At 09:07 PM 9/1/2011, you wrote:
| Quote: | Thanks to all for your comments and suggestions.
Has anyone heard of the Narco VP-16? Another guy on the list has one for sale but I have no experience with them. Would it be suitable to safely split the signal? I'd hate to risk damaging two high dollar radios. |
I've attached a sketch for a modern incarnation
of the device I mentioned earlier today. It takes
4, surface mounted dpdt relays. The relays are wired
such that when neither PTT is active, the receivers
are both connected to the antenna through a modern
power splitter.
Energize either PTT and the opposite receiver is
disconnected, it's audio is quieted through a set
of relay contacts and the splitter is isolated from
the antenna.
The whole assembly can be put on an etched circuit
board about 2" x 2.5". Power, audio and PTT signals
are brought off through a 9 pin d-sub. The relays
are miniature DPDT devices mounted over a solid
ground plane to minimize effects to feed-line
integrity.
It's configured such that +14v power has to be
present on the board before EITHER radio can be
keyed. This prevents loss of power from allowing
a transmitter to be keyed without benefit of
protection by transferring the proper contacts.
Auto_Antenna_Switch.pdf |
52.84 KB |
315 Time(s) |
