nigel(at)yakdisplay.com Guest
Posted: Wed Aug 24, 2011 9:42 pm Post subject: Seized exhaust rings - Yak52 M14P |
Can anyone help?
Am in a bit of a pickle with our Yak52 so am after advice and possible parts if we can….
A couple of exhausts have come loose (M14P engine) – and the rings are locked solid – we can’t budge them. The holes for the special tool have long since been mauled away.
The exhausts in question are (viewed from INSIDE the cockpit) the very top cylinder, and the one to the immediate right of it (12 o’clock and 1 o’clock). The top cylinder is a 45 degree angle short piece, and the next one is a T-piece.
The questions are:
<![if !supportLists]>1. <![endif]>Do you have any bright ideas how to get the rings off without cutting them or damaging the cylinder head threads?
<![if !supportLists]>2. <![endif]>Do you sell the rings and olives separate (we could cut the existing exhaust to get the new ones on and re-weld exhaust)?
<![if !supportLists]>3. <![endif]>Do you sell the two exhaust parts in question complete with the rings and olives?
As usual, we’ve got a display booked for this weekend – your advice and help would be very welcome!
Perhaps you could let us know ASAP….. and costs if anyone has anything appropriate….
Thanks in advance
Nigel
Posted: Thu Aug 25, 2011 5:01 am Post subject: Seized exhaust rings - Yak52 M14P |
Your problem is not unusual Nigel. Although I'm sure there are 100's of
suggestions on how to loosen the exhaust collars, I will share what I
have used in the past with only moderate success. That means it does not
work in every situation. The last resort is as you mentioned, cutting
the collar off the threaded exhaust port, then cutting the exhaust
section, installing a new collar and welding the exhaust section
precisely in the same position.
I have soaked the threads around the exhaust collar with;
- PB Blaster
- Mouse Milk
You will have to soak the threads heavily and let them sit for several
hours.
I have also heated the collar using a propane torch and then tried
turning it. BUT not with PB Blaster or Mouse Milk on the threads.
Especially if the stuff is still liquid. It's flammable.
Before reinstalling the threaded collar on the exhaust port, be sure to
thoroughly clean the threads with a wire brush. If reusing the original
collar, be sure to thoroughly clean the threads on it as well. Then I
put copper based anti-seize compound around the port and collar threads,
like the type one would use on the spark plug threads. This seems to
help, should you ever need to tighten or loosen the collar again.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 8/25/2011 1:08 AM, Nigel Willson wrote:
Can anyone help?
if we can….
one is a T-piece.
The questions are:
1. Does anyone have any bright ideas how to get the rings off without
2. Does anyone sell the rings and olives separate (we could cut the existing
3. Does anyone sell the two exhaust parts in question complete with the
rings and olives?
appropriate….
Thanks in advance
Nigel
dougsappllc(at)gmail.com Guest
Posted: Thu Aug 25, 2011 9:29 am Post subject: Seized exhaust rings - Yak52 M14P |
Nigel,
The best penetrating fluid I have found to date is a 50/50 mix of ATF
and acetone. This mix seems to go where MM and most others won't. I have
no experience with PB Blaster.
The replacement exhaust nuts can be installed without cutting and re welding
the pipe, this is done with the use of a jewelers saw and a tig welder.
Call me if you need me to walk you through it. I have done it many times.
Care needs to be taken when attempting to remove a stuck exhaust nut as the
exhaust boss (the part the exhaust nut screws on to) is simply threaded
into, then staked in the alu cylinder head. Excessive force can loosen the
stake or strip the threads out of the cyl. Go slowly and carefully.
Best,
Doug
509-826-4610
On Thu, Aug 25, 2011 at 5:59 AM, A. Dennis Savarese <
suggestions on how to loosen the exhaust collars, I will share what I have
used in the past with only moderate success. That means it does not work in
every situation. The last resort is as you mentioned, cutting the collar off
the threaded exhaust port, then cutting the exhaust section, installing a
new collar and welding the exhaust section precisely in the same position
dandmaz(at)cox.net Guest
Posted: Thu Aug 25, 2011 9:38 am Post subject: Seized exhaust rings - Yak52 M14P |
good to see you back in the saddle .
Don
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Thursday, August 25, 2011 10:26 AM
To: yak-list(at)matronics.com
Subject: Re: Yak-List: Seized exhaust rings - Yak52 M14P
Nigel,
The best penetrating fluid I have found to date is a 50/50 mix of ATF and acetone. This mix seems to go where MM and most others won't. I have no experience with PB Blaster.
The replacement exhaust nuts can be installed without cutting and re welding the pipe, this is done with the use of a jewelers saw and a tig welder. Call me if you need me to walk you through it. I have done it many times.
Care needs to be taken when attempting to remove a stuck exhaust nut as the exhaust boss (the part the exhaust nut screws on to) is simply threaded into, then staked in the alu cylinder head. Excessive force can loosen the stake or strip the threads out of the cyl. Go slowly and carefully.
Best,
Doug
509-826-4610
On Thu, Aug 25, 2011 at 5:59 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Your problem is not unusual Nigel. Although I'm sure there are 100's of suggestions on how to loosen the exhaust collars, I will share what I have used in the past with only moderate success. That means it does not work in every situation. The last resort is as you mentioned, cutting the collar off the threaded exhaust port, then cutting the exhaust section, installing a new collar and welding the exhaust section precisely in the same position.
- PB Blaster
- Mouse Milk
You will have to soak the threads heavily and let them sit for several hours.
I have also heated the collar using a propane torch and then tried turning it. BUT not with PB Blaster or Mouse Milk on the threads. Especially if the stuff is still liquid. It's flammable.
Before reinstalling the threaded collar on the exhaust port, be sure to thoroughly clean the threads with a wire brush. If reusing the original collar, be sure to thoroughly clean the threads on it as well. Then I put copper based anti-seize compound around the port and collar threads, like the type one would use on the spark plug threads. This seems to help, should you ever need to tighten or loosen the collar again.
Dennis
A. Dennis Savarese
[url=tel:334-285-6263]334-285-6263[/url]
[url=tel:334-546-8182]334-546-8182[/url] (cell)
Skype: Yakguy1
www.yak-52.com
--> Yak-List message posted by: "Nigel Willson"<nigel(at)yakdisplay.com (nigel(at)yakdisplay.com)>
Can anyone help?
if we can….
one is a T-piece.
The questions are:
rings and olives?
appropriate….
Thanks in advance
Nigel
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
