galinhdz(at)gmail.com Guest
Posted: Sun Aug 21, 2011 7:31 am Post subject: Guden gas springs |
Where can I get a pair of the Guden GGS22-030-K gas springs? Mine are starting to have a hard time keeping one of the doors open?
Galin [quote][b]
fredorosa(at)gmail.com Guest
Posted: Sun Aug 21, 2011 7:57 am Post subject: Guden gas springs |
Go to: guden,com
On Sun, Aug 21, 2011 at 11:31 AM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote] Where can I get a pair of the Guden GGS22-030-K gas springs? Mine are starting to have a hard time keeping one of the doors open?
Galin | Quote: |
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
| [b]
punchy(at)frontiernet.net Guest
Posted: Sun Aug 21, 2011 8:27 am Post subject: Guden gas springs |
While we're at it, what is recommended for the TR-1? I also have one
that is not keeping the door open.
Rob
On 8/21/2011 8:57 AM, ALFRED ROSA wrote:
| Quote: | GGS22-030-K gas springs
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Sun Aug 21, 2011 9:06 am Post subject: Guden gas springs |
Galin,
You are welcome to the two that I have since I will probably not use them. Current plan is to buy a set of four matched for my installation. (If I ever get back to work on it that is.)
Bob
To: "kis-list(at)matronics.com" <kis-list(at)matronics.com>
Sent: Sun, August 21, 2011 10:31:12 AM
Subject: KIS-List: Guden gas springs
Galin [quote][b][b]
Posted: Sun Aug 21, 2011 9:15 am Post subject: Guden gas springs |
Galin,
Are you using just one 30lb spring per door? If so, you may do better with 40lb. springs.
Al
On Sun, Aug 21, 2011 at 1:05 PM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
[quote]Galin,
Bob
From: Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)>
To: "kis-list(at)matronics.com (kis-list(at)matronics.com)" <kis-list(at)matronics.com (kis-list(at)matronics.com)>
Galin | Quote: |
[quote] Galin,
Bob
Galin | Quote: |
Posted: Sun Aug 21, 2011 9:18 am Post subject: Guden gas springs |
Bob,
Is that Texas heat holding you up? In Fl my garage gets so hot at times, after 20 minutes I have to quit and jump in the pool.
Al
On Sun, Aug 21, 2011 at 1:15 PM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
| Quote: | Galin,
Bob
Galin | Quote: |
ftyoder(at)yoderbuilt.com Guest
Posted: Sun Aug 21, 2011 9:54 am Post subject: Guden gas springs |
The gas struts that came with my kit, in 93, were not strong enough. I think
they are Supra rated at 25#, I refilled them in a Nitrogen cylinder and it
boosted them to 35/40#'s and they have held up for several years.
Robert Reed
Posted: Sun Aug 21, 2011 11:04 am Post subject: Guden gas springs |
No, HELL is holding me up. With only two days below 100 degrees in the last two months it's impossible to even work in my shop which has a window unit. The best I can get the temp down to is about 90 degrees if I leave the unit running all night. The unit works when the temps stay in the 90's but with night time lows in the mid 80's it just too hot. Can't even consider working at the hangar. Hopefully by mid-September I can restart since the gutting and rebuild on the kitchen is finally complete.
The issue now is time and money which are both in very short supply.
Bob
To: kis-list(at)matronics.com
Sent: Sun, August 21, 2011 12:17:50 PM
Subject: Re: Guden gas springs
Bob,
Al
| Quote: | Galin,
Bob
Subject: Guden gas springs
Galin
| Quote: | [b]
[b] |
bakerocb
Posted: Mon Aug 22, 2011 5:38 am Post subject: Guden gas springs |
8/22/2011
Hello Galin, See here:
http://www.guden.com/control-Home.aspx
If your order is too small to be accepted over the net try the telephone.
They have been always very helpful and gracious to me on the phone even when
just ordering two struts.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 08:31:35 AM PST US
Galin
