georgerace
Posted: Mon Aug 15, 2011 3:03 am Post subject: Tie Wraps |
Good morning
In you second picture, I noticed you built up a standoff for your flexible cable using two tie wraps. A very acceptable procedure. Just a note of caution to go along with what is showing the picture. Here in MI our FAA Inspectors will not approve any build that has a tie wrap directly applied to any engine mount tubing. They insist that eventually it will score the tubing causing a weak area where it is located. It is allowed if you first wrap a couple of turns of Scotch 66 or 88 tape around the tubing first and then tighten the tie wrap on the taped over tubing.
The rules may differ where you are,
George
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Clive Richards
Sent: Monday, August 15, 2011 5:07 AM
Subject: Re: 601 owners... something to watch for - engine mount fittings
Carlos
I donot have the drawing here to check number but pictures attached. before & after replacement .
Clive
----- Original Message -----
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Sent: Sunday, August 14, 2011 7:55 PM
Clive, are you talking about 6F8-2?
Carlos
On 14 August 2011 14:36, Clive Richards <s.clive.richards(at)homecall.co.uk (s.clive.richards(at)homecall.co.uk)> wrote:
Michel
We found the cross channel in the engine compartment cracked on the Left side about 6 years ago on Rays 601 HD with 0-200 when changing Bungee, suspected we had cut off to much material near engine mount, replaced with a thicker channel and carried the L angle above completely across fire wall as noticed they had done this on the XL, have done another 400 hrs since with no problem.
Clive
G CBDG 460 Hrs
| Quote: | | href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | [b]
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
BARRY CHECK 6
Posted: Mon Aug 15, 2011 5:08 am Post subject: Tie Wraps |
Unbelievable George...
Just shows you how totally unrealistic the FAA/Government can be. TOTALLY DUMB! The ONLY issue I would have is if the engine mount is NOT painted.
Shows how much they know about materials, hardness (Rockwell Vs Shore) and even a simple thing like Mohs Scale.
That's what happens when give too much power to idiots!
Barry
On Mon, Aug 15, 2011 at 6:55 AM, George Race <mykitairplane(at)mrrace.com (mykitairplane(at)mrrace.com)> wrote:
Good morning
George
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com)] On Behalf Of Clive Richards
Carlos
Clive
Carlos
Michel
Clive
G CBDG 460 Hrs
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
