Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Mon Aug 08, 2011 6:36 pm Post subject: Red Fuel Transducer Mount - Firewall |
There was a discussion about alternate mounting if the red fuel transducer. I put mine on the lower right side of the firewall. Used 45 Degree fittings at the transducer. No fuel pump fluctuations and not engine mounted. Both fuel lines are adele clamped to the engine mount to reduce vibration loads on the cube.
Jim Combs
N312F - 270+ hours
296.71 KB |
1585 Time(s) |
247.98 KB |
1585 Time(s) |
_________________ RV-10 -> N312F - Flying as of 12/2008 |
