Under cowl antenna mount
Jim Combs
PostPosted: Mon Aug 08, 2011 6:33 pm    Post subject: Under cowl antenna mount Reply with quote
There was some discussion a while back about mounting GPS and Weather antenna's.  Here is my solution.
I have a Garmin 430W GPS antenna, a stand alone GPS serial receiver and the XM weather antenna's all mounted under the cowling.  No issues in 270+ hours.
The stand alone GPS unit drives the AFS Autopilot and the copilot AFS-3500 EFIS.  The Garmin GPS is driving the pilot side AFS-4500 EFIS.
They are forward enough to have a good view of the sky.
The $30 GPS receiver is this one:
http://www.amazon.com/Serial-GPS-Reciever-Cable-Kit/dp/B000VUFGF8
Jim Combs
N312F - 270+ hours
 Filesize:  151.97 KB
 Viewed:  2025 Time(s)
 Filesize:  223.72 KB
 Filesize:  248.28 KB
RV-10 -> N312F - Flying as of 12/2008
