acs(at)acspropeller.com.a Guest
Posted: Fri May 19, 2006 1:06 am Post subject: Weight of Hartzell 2 bld |
Sorry Deems, the chart info didn't reproduce correctly. Short answer 50lbs approx.
John 40315
Deems Davis
Posted: Fri May 19, 2006 3:24 am Post subject: Weight of Hartzell 2 bld |
Thanks John
John Dunne wrote:
Quote: | Sorry Deems, the chart info didn't reproduce correctly. Short answer
50lbs approx.
John 40315
LessDragProd(at)aol.com Guest
Posted: Fri May 19, 2006 9:02 am Post subject: Weight of Hartzell 2 bld |
50 pounds? That's it? Is this the best the RV-10 list can do?
I am willing to say that the Hartzell 80" diameter blended airfoil propeller and spinner assembly weighs at least 65 pounds ready to bolt ontothe engine.
The Hartzell 72" diameter propeller and spinner assy with 7666-4 blades weighs 56 pounds.
The Hartzell 80" diameter propeller and spinner assy weighs 66 pounds.
I would suggest that the blended airfoil blades are not significantly lighter than the standard aluminum blades.
Is someone on the RV-10 list actually willing to weigh their Hartzell blended airfoil propeller and spinner assembly to provide a REAL weight?
Jim Ayers
In a message dated 05/19/2006 4:25:46 AM Pacific Daylight Time, deemsdavis(at)cox.net writes:
Quote: | --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
Thanks John
50lbs approx.
John 40315
brinker(at)cox-internet.c Guest
Posted: Fri May 19, 2006 9:45 am Post subject: Weight of Hartzell 2 bld |
&nbs p; I've got an 80" CS still in the box I'll try to weigh it this weekend if I have time and let you know.
Randy
JSMcGrew(at)AOL.COM Guest
Posted: Fri May 19, 2006 10:22 am Post subject: Weight of Hartzell 2 bld |
Mine weighed in at 57 lbs.
Jim McGrew
40134
In a message dated 5/19/2006 11:07:43 A.M. Mountain Daylight Time, LessDragProd(at)aol.com writes:
Quote: | < FONT style"BACKGROUND-COLOR: transparent" faceArial color#000000 size 2> 50 pounds? That's it? Is this the best the RV-10 list can do?
I am willing to say that the Hartzell 80" diameter blended airfoil propeller and spinner assembly weighs at least 65 pounds ready to bolt ont othe engine.
Jim Ayers
Thanks John
John Dunne wrote:
Quote: | Sorry De ems, the chart info didn't reproduce correctly. Short answer
50lbs approx.
John 40315
Jim "Scooter" McGrew
jsmcgrew(at)aol.com
bcondrey(at)cox.net Guest
Posted: Fri May 19, 2006 12:48 pm Post subject: Weight of Hartzell 2 bld |
I just weighed mine - 53.6 lbs. That is a new Hartzell 2 blade blended
airfoil prop as ordered from Vans and delivered from Hartzell. Does not
count any spinner/backplate related hardware - just the prop w/blades and
hub as delivered.
Bob #40105
Subject: Re: Weight of Hartzell 2 bld
Date: Fri May 19 - 10:02 AM
propeller
and spinner assembly weighs at least 65 pounds ready to bolt onto the
engine.
weighs 56 pounds.
Jim Ayers
Thanks John
bgill1(at)charter.net Guest
Posted: Fri May 19, 2006 6:35 pm Post subject: Weight of Hartzell 2 bld |
Hartzell 80" diameter blended airfoil propeller.
Around 54 pounds bare.
Around 57 pounds with spinner installed.
That is impressive.
Jim Ayers
PS this is not sarcasm.
The Hartzell 2 blade 80" diameter propeller assembly used on the Harmon Rocket 2 weighs 66 pounds.
Posted: Sat May 20, 2006 7:36 am Post subject: Weight of Hartzell 2 bld |
Weighed my 80" c/s Hartzel complete with spinner assembly on a pair of digital bath scales and got 56.0 pounds exactly on three different weigh-in's on the same scales. Letting the scales recalibrate on each weigh-in.
Randy
