rv10builder(at)bellsouth. Guest
Posted: Thu May 18, 2006 6:11 pm Post subject: Airflow Performance Fuel Injection |
I was just looking over my new Airflow Performance fuel injection system
and noticed the purge valve with a return fitting. How does anyone
using this system plan on connecting it up?
Brian
#40308
http://www.mykitlog.com/rv10builder
Dave(at)AirCraftersLLC.co Guest
Posted: Thu May 18, 2006 8:19 pm Post subject: Airflow Performance Fuel Injection |
Brian,
One thing to consider with the purge valve:
We worked on a plane that had the valve oriented so the shaft pointed up.
We had replaced the engine isolators among other work and I suspect rasied
the engine a tiny bit. We ran it without the cowl for a while, and it ran
fine. When we put the cowl on (I know, we should have checked), the top
cowl barely contacted the purge valve shaft, pressing it down into its
housing. That kept the engine from starting since the shaft displacement
created an extreme over-rich condition. Cowl on, no start. Cowl off, ran
great. That took a while to figure out...make sure the shaft is well clear!
That installation ran the purged fuel back to a header tank (ideally...).
Dave Saylor
AirCrafters LLC
831-722-9141
40394 QB, wings done, baggage floors in
Posted: Fri May 19, 2006 2:41 am Post subject: Airflow Performance Fuel Injection |
I have an andair duplex valve and will be returning the purge fuel back to
the same tank...otherwise, you need to placard for selecting the same fuel
side that your return is plumbed to or risk pumping it overboard.
My purge valve is mounted 'lay-down' style insteda of between the cylinders
as I am using a sam james plenum. Contact AirflowPerformance - they can
swap out the purge valve if you need to avoid cowl interference issues.
carl.froehlich(at)cox.net Guest
Posted: Fri May 19, 2006 1:59 pm Post subject: Airflow Performance Fuel Injection |
I run the Airflow Performance on my RV-8A. I use the purge valve for engine
shut down, but it's main function is to eliminate vapor lock in the spider
for hot starts (never had to do this - 250 hrs so far).
I have the purge line plumbed back to one tank. Considering the very
infrequent use for purging, and that purge volume is only a few ounces, they
is no need for a duplex fuel valve.
Carl Froehlich
RV-10 (tail)
RV-8A (flying)
Posted: Fri May 19, 2006 5:46 pm Post subject: Airflow Performance Fuel Injection |
Thanks for the responses; all contained good information! After a
little searching on the WEB I found an attractive solution:
http://www.rvproject.com/20030516.html
Thanks Dan!
rv10builder wrote:
Quote: | I was just looking over my new Airflow Performance fuel injection
system and noticed the purge valve with a return fitting. How does
anyone using this system plan on connecting it up?
Brian
#40308
PILOTDDS(at)aol.com Guest
Posted: Fri May 19, 2006 8:40 pm Post subject: Airflow Performance Fuel Injection |
Instructions are very clear and it is a great system.Good people to work with.
&nbs p; &n bsp; 728DD
