Fuel Tank Vents
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
javiercarrascob
PostPosted: Wed Jul 27, 2011 6:59 pm    Post subject: Fuel Tank Vents Reply with quote
Hello Team,
I'd been following the "fuel flow from tanks" topic and in the same token I have a question regarding the Fuel Vents.
I have noticed small drops falling from the right wing (when looking at it sitting in flying position in my Yak-55m), the first time I noticed was doing vertical flight but I dismissed as condensation or rain as the plane sat overnight with no covers while there was a storm (and yes as soon as I preflight the plane I saw water coming off the ailerons.)
So I decided to look at again and I can see what I think is fuel drops leaving the plane from the right wing while doing acro (inverted or vertical) but it is only from the right wing and it does not amount to anything on the fuel levels (if I fly heavy on the right wing I have more fuel there if I fly heavy on the left, it cross feed to the left).
While I do cross country, there is no loss of fuel so leveled flight or seating on the tarmac means no fuel loss.
So is this normal? and I never noticed before? I assume that some fuel will get caught in the fuel vents and can drip off. but I rather hear your opinions.
Thanks, Javier
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
