blumax008(at)aol.com Guest
Posted: Mon Jul 11, 2011 11:38 pm Post subject: Need advice 503 Rotax/ Bing dual carbs/ oil injected |
There certainly is old buddy and you picked a good, reliable, easy to maintain motor. The website to order the video is...
www.homebuilthelp.com
It's called Deep Inside your Rotax 2 Cycle Engine
The one I have is of a 582 and I don't know for sure if they've released one for the 503 yet or not. I can say that the 582 video was helpful in a lot of regards to the 503 such as carb. teardown, gearbox removal etc. etc.
Dennis Thate
Posted: Sun Jul 17, 2011 9:57 am Post subject: Re: Need advice 503 Rotax/ Bing dual carbs/ oil injected |
Thanks for the link !
Part of my problem was this: ......... See Photos below
When I purchased my plane those lines are vent lines to keep barometric pressure on top of the fuel in the bowls. If the holes are not in that line, low pressure will build up off idle and not run.
Mine were looped, so I cut them both on each carb. Rotax now runs smooth.
| Description: |
| Filesize: |
53.2 KB |
| Viewed: |
2749 Time(s) |
| Description: |
| Filesize: |
66.76 KB |
| Viewed: |
2749 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
