Trying to identify CJ part found at gib's feet
thomasg(at)infosysnetwork
PostPosted: Fri Jul 01, 2011 7:45 am    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
Yesterday after my flight, I found a small 1" x 1.25" (approx) metal plate with two screws and a hole in the center. It was at my gib's right foot. I'm trying to identify it and figure out where it belongs.
Any ideas?
Pictures are attached
 Filesize:  386.26 KB
 Viewed:  6921 Time(s)
 Filesize:  383.14 KB
 Filesize:  272.67 KB
talew(at)bellsouth.net
PostPosted: Fri Jul 01, 2011 7:59 am    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
I could be an instrument panel mount . I'll check my plane later today .
Terry
threein60(at)yahoo.com
PostPosted: Fri Jul 01, 2011 8:38 am    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
It appears to be an avionics shock mount from the instruments behind the pilots seat..
Larry Pine
N8181C
CJ6/m14p
Terry
wlannon(at)persona.ca
PostPosted: Fri Jul 01, 2011 9:22 am    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
I believe it is the end cap / pivot bearing for rudder pedal position
adjusting screw. Probably from the rear cockpit..
With a mirror and flashlight inspect the forward end of the adjustment screw
housing in both cockpits. You will see a notable difference if that is the
case.
Walt
dhanshew(at)cinci.rr.com
PostPosted: Fri Jul 01, 2011 10:56 am    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
---- Thomas, Looks like one of the old radio mounts.
Any ideas?
PostPosted: Fri Jul 01, 2011 5:20 pm    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
Tom;
Further to my last - confirmed today that identification is correct.
Walt
PostPosted: Sun Jul 03, 2011 7:18 pm    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
Yep, that was it. Got some new screws & going to put it back on tomorrow. Without it, no rudder control for the gib! Thanks for the help.
Tom
HawkerPilot2015
PostPosted: Tue Jul 05, 2011 8:27 pm    Post subject: Re: Trying to identify CJ part found at gib's feet Reply with quote
Some sort of Chinese tracking device or spy microphone?
f4ffm2(at)roadrunner.com
PostPosted: Tue Jul 05, 2011 8:42 pm    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
I think it was some sort of malevolent Chinese device designed to prevent any camera in its vicinity from focusing.
http://forums.matronics.com/viewtopic.php?p=345070#345070
Roger E. Baker, Managing Director
Panadero Energy Components, LLC
dba PEC AirAssist
760/809-5506
760/730-9244
760/454-4595 fax
pilko2(at)btinternet.com
PostPosted: Tue Jul 05, 2011 11:58 pm    Post subject: Trying to identify CJ part found at gib's feet Reply with quote
Excellent.... LOL
