stick grip
pitts_pilot(at)bellsouth.
PostPosted: Thu Jun 30, 2011 6:35 pm    Post subject: stick grip Reply with quote
I'm trying to decide which stick grip to install ..... the choices are
not insignificant. I'd like to know what the flying RV-10s are using
for their stick grip and their recommendations.
A few questions:
Which grip did you choose and why.
Did it meet your expectations?
Did you find that you needed more functions? Which ones?
Would you list the buttons you have and their function?
Do you wish you'd installed another grip, and why?
If you want to reply directly, I'll post a summary in a week or two.
Linn
rene(at)felker.com
PostPosted: Fri Jul 01, 2011 5:14 am    Post subject: stick grip Reply with quote
See answers below
Rene' Felker
N423CF
801-721-6080
dmaib(at)mac.com
PostPosted: Fri Jul 01, 2011 5:26 am    Post subject: stick grip Reply with quote
I have the Infinity grips. I chose them because I liked the feel and
look, good reputation, and the number of possible functions. I have
the coolie hat on top controlling elevator trim and aileron trim.
Green button to the left flip-flops comm 1 frequencies, black button
to the right is the Vertical Power "Acknowledge" button and checklist
advance, red button halfway down on the right is autopilot disconnect/
CWS, the trigger switch is PTT for the comm radios, and I have a
pinkie switch that is left-off-right for rudder trim. If I was doing
it again, I would not put the rudder trim switch on the grip, but
would have a starter button instead. Other than that, I am very happy
with the grip and the functions.
David Maib
40559
Flying
On Jun 30, 2011, at 10:33 PM, Linn Walters wrote:
<pitts_pilot(at)bellsouth.net>
are not insignificant. I'd like to know what the flying RV-10s are
using for their stick grip and their recommendations.
A few questions:
Linn
daveleikam(at)wi.rr.com
PostPosted: Fri Jul 01, 2011 5:59 am    Post subject: stick grip Reply with quote
I really like my Tosten CS-8 grip very much. Good price, made well. I like having fewer buttons, and the grip is very comfortable. Trigger is talk, small button under the trigger is CWS or AP disconnect, hat is trim, left button is com 1 freq swap and right button is ident.
David Leikam
RV10
Flying
On Jul 1, 2011, at 8:23 AM, David wrote:
I have the Infinity grips. I chose them because I liked the feel and look, good reputation, and the number of possible functions. I have the coolie hat on top controlling elevator trim and aileron trim. Green button to the left flip-flops comm 1 frequencies, black button to the right is the Vertical Power "Acknowledge" button and checklist advance, red button halfway down on the right is autopilot disconnect/CWS, the trigger switch is PTT for the comm radios, and I have a pinkie switch that is left-off-right for rudder trim. If I was doing it again, I would not put the rudder trim switch on the grip, but would have a starter button instead. Other than that, I am very happy with the grip and the functions.
David Maib
40559
Flying
> I'm trying to decide which stick grip to install ..... the choices are not insignificant. I'd like to know what the flying RV-10s are using for their stick grip and their recommendations.
> A few questions:
> Linn
carl.froehlich(at)verizon
PostPosted: Fri Jul 01, 2011 6:34 am    Post subject: stick grip Reply with quote
I first did the starter button (pinky switch) on the Infinity grip on my 8A.
In addition to the need to add another relay (the switch does not have the
current rating to control the starter solenoid directly) I found it way too
easy bump with the switch with the engine running. I disconnected it after
a few hours.
On the 10, the switches are:
Trim (coolie hat)
Flap
AP engage/disengage
PTT
Comm flip/flop
I do have a locking toggle switch on the panel to select who has control of
trim and flaps (pilot or co-pilot). I do this by controlling the common
ground wire. My thought was to prevent a non-pilot in the seat from doing
something weird, and to have an installed spare switch if the pilot stick
controls fail.
Carl
Bob Turner
PostPosted: Fri Jul 01, 2011 4:57 pm    Post subject: Re: stick grip Reply with quote
I have the Tosten on the left stick, and like the feel of it. I just use 3 functions: top hat for trim, trigger for PTT, and right rear button for autopilot disconnect. The right stick has an inexpensive Allen (I think) grip with just PTT. I don't want passengers hitting the trim switch. I installed the Allen rocker trim switch in the right-center panel, easily reached by either pilot, as a second way of running trim from the left seat or the main way from the right. My Trio autopilot will also run the trim, automatically or manually.
I have the trim speeds set so the left stick runs full speed; the panel rocker runs a little slower; and the Trio auto-adjusts to run fast when airspeed is low, and runs trim slowly when airspeed is high.
Bob Turner
RV-10 QB
n223rv(at)wolflakeairport
PostPosted: Fri Jul 01, 2011 5:45 pm    Post subject: stick grip Reply with quote
I used the Teak wooden grips on my RV-4 and liked them so much that I am using them on my RV-10. I have the coolie hat for trim, a PTT and an autopilot disconnect. I am very happy with them.
-Mike Kraus
40013, 19.8 hours
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=344639#344639
 Filesize:  245.06 KB
 Viewed:  8707 Time(s)
Kelly McMullen
PostPosted: Fri Jul 01, 2011 6:13 pm    Post subject: stick grip Reply with quote
Vans or other source?
On Fri, Jul 1, 2011 at 6:41 PM, Michael Kraus
-Mike Kraus
40013, 19.8 hours
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Kelly McMullen
Disregard. Didn't see the image attached .
> -Mike Kraus
> 40013, 19.8 hours
Kelly McMullen
KCHD
dave.saylor.aircrafters(a
PostPosted: Fri Jul 01, 2011 6:46 pm    Post subject: stick grip Reply with quote
I have the same setup as Mike. I'm happy with it, but it took a few changes.
For one, I originally had the trim in the upper left corner, and the
AP disconnect in the lower right corner. I'm describing the left
side. The right side is a mirror image. Each one kind of felt
natural under my thumb. But I found that especially on take-off, if I
didn't have the trim quite right for the load, that it was pretty
difficult to push on the stick (which happens with your thumb) while
also reaching up with my thumb to trim the nose down. Many times I
ended up pushing with one hand and trimming with the other. Two
annuals ago I swapped the two buttons and now it's much easier to trim
and push at the same time.
The other change was to put a guard on the AP button. It was pretty
easy to accidentally push it with a map, especially on the right side.
It's just a simple dish that protects the button.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
-Mike Kraus
40013, 19.8 hours
> Bob Turner
> RV-10 QB
<pre><b><font size=2 color"#000000" face="courier new,courier">
</b></font></pre>
PostPosted: Fri Jul 01, 2011 11:03 pm    Post subject: stick grip Reply with quote
Oops, I didn't see the image either--my grips are from Vans.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Fri, Jul 1, 2011 at 7:42 PM, Dave Saylor
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
> -Mike Kraus
> 40013, 19.8 hours
> Sent from my iPhone
>> Bob Turner
>> RV-10 QB
> </b></font></pre>
rv10flyer
PostPosted: Sun Jul 03, 2011 6:16 am    Post subject: Re: stick grip Reply with quote
Fabricated my own out of African zebrawood. CWS/PTT on pilot side and PTT on copilot side.
Wayne G.
