sapril001(at)hotmail.com Guest
Posted: Fri Jun 17, 2011 5:23 am Post subject: M-14P EGT |
Hi all,
What should be the red line for the EGT on a M-14P engine.
Sylvain April
Murphy Moose M-14P
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
george(at)gesoco.com Guest
Posted: Fri Jun 17, 2011 5:49 am Post subject: M-14P EGT |
2,950 RPM at the crankshaft or 1,860 RPM at the propeller.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Sylvain April
Sent: Friday, June 17, 2011 9:21 AM
To: m14pengines-list(at)matronics.com
Subject: M-14P EGT
Hi all,
Sylvain April
Murphy Moose M-14P
Quote: | http://www.matronics.com/Navigator?M14PEngines-List | 01234567
MONTY(at)bpaengines.com Guest
Posted: Fri Jun 17, 2011 6:19 am Post subject: M-14P EGT |
I have never seen a limitation published on EGT for aircraft engines. There are turbine inlet temp. limits but not EGT.
IN our test cell we have seen up to 1525 F but that was at Cruise 1 power and maximum lean. Typical full power EGT when the carb is correctly jetted will give around 1450 F.
EGT is a variable and depends on a lot of physical characteristics besides fuel-air ratio. Iti should be used as a trend monitoring temperature.
Monty Barrett
Barrett Precision Engines, Inc.
